DII spring spacer question - Defender Source
Old August 8th, 2013, 11:27 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Anyone know the diameter of the inside of the lower spring perch on the rear of a DII? Trying to make some spacers for a buddy and need to by material. Basically what diameter slug will fit?
Old August 8th, 2013, 11:33 PM
Rover springs are 6" outside diameter. The inside varies a bit depending on the wire size used.
ac
DII pinion flange question Tyler Wirken Defender Technical Discussions 11 July 26th, 2013 01:06 PM
Another Spring Question bossman429 Defender Technical Discussions 18 December 18th, 2012 06:35 AM
Will these work? Shock spring question. tomaco1 Defender Technical Discussions 0 May 5th, 2009 09:34 PM
Weight surprise at scales and spring question KevinNY Defender Technical Discussions 0 March 2nd, 2006 12:34 PM
Yet another spring question... JackW Defender Technical Discussions 2 January 30th, 2006 11:13 AM
