Differntial fluid diahrea - Defender Source
Old July 23rd, 2013, 10:22 PM
molonlabedoc
Vincent
1987 D90
I have a nice leak taking place on my right rear on the inside of the tire. Could this be the gasket?
My first project!
Old July 23rd, 2013, 10:56 PM
Could be. Start by cleaning out the breather.
Old July 23rd, 2013, 10:59 PM
molonlabedoc
Vincent
1987 D90
Roger thanks, just read about the breather via search. Bit of a noob here.
Old July 24th, 2013, 12:26 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Or your hub seal. Start with the breather though, its easier.
Old July 24th, 2013, 12:53 AM
molonlabedoc
Vincent
1987 D90
Thanks everyone!
Old July 24th, 2013, 07:07 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
You can take breather off the banjo bolt or better yet to take the banjo off with he breather to make sure the line is entirely clear. You should have two copper washers on the banjo bolt so don't loose them.... I would also check the diff fluid level as it may be low after the leak. After cleaning everything up and you still have a leak you can start looking at the hub and the hub seals. If you do not have a workshop manual you can do a search and find some on the web. This will give you all of the information you need to help search out the problem.
Old July 24th, 2013, 07:11 PM
molonlabedoc
Vincent
1987 D90
Well I did both breathers. Front was as clean as all can be, but the back (where the leak is on the right inner tire) was essentially full of it.
I changed the dif fluid in the rear and will do the front Thursday. Good fun. Thanks for the info/
Old July 24th, 2013, 09:22 PM
I would be that was the cause of the leak.
Gear fluid ..... Rover- Girl Defender Technical Discussions 3 October 9th, 2005 05:25 PM
Power Steering Fluid Reservior fleabus Defender Technical Discussions 3 July 22nd, 2005 10:39 AM
ZF fluid level goes up and down 48vphantom Defender Technical Discussions 4 March 20th, 2005 01:42 PM
