Differential torque - Defender Source
Old April 22nd, 2016, 08:47 AM
Gabriel_Laconi
Gabriel
1992 Rangge Rover
Differential torque
I just replaced all the bearings on the rear diff of my 1992 RRC. I torqued the pinion nut and its hard to move. Does anybody know the torque spec, or should it just be tight enough to remove slack...? I know there is a retaining pin, so i wonder how tight it really needs to be...
-Gabe.
Old April 22nd, 2016, 09:20 AM
there is a procedure and torque settings for that, using an inch pound torque wrench and shims under the outer bearing.
If you haven't followed that procedure, you are doing it wrong.
-Gabe.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old April 22nd, 2016, 09:30 AM
Read the manual. The nut is meant to be very tight. The bearing preload is set by changing shims.
Old April 22nd, 2016, 10:15 AM
Gabriel_Laconi
Gabriel
1992 Rangge Rover
I just keep finding contradicting info...some say tighten the nut, but too tight and i dont meet the 20-35 lbs/In. turning force...i hear a clunking noise at low speeds. If i loosen the pinion nut a bit the diff spins freely...
Old April 22nd, 2016, 10:23 AM
There is zero contradictory information. READ THE MANUAL!!!!!!
The bearing preload is set with shims not by nut tightness. The nut should be very tight. You need more shim.
Old April 22nd, 2016, 10:24 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
You really need to follow the manual.
It helps to have setup races and a setup pinion nut(non-nylock or worn-in nylock). You need to add/remove shims and torque the pinion nut to spec, then check the preload with an INCH/lb beam torque wrench. Once you get it dialed in install your final races and torque a nylock pinion nut to spec. All that is after you check you gear pattern, of course.
You can make set up races by taking a new race and grinding a little off the outside, just enough so you can drop it in and take it out without tools.
Old April 22nd, 2016, 10:43 AM
Gabriel_Laconi
Gabriel
1992 Rangge Rover
I guess i dont understand what keeps the pinion bearings from binding when i tighten the pinion nut. The shims wont prevent the bearings from crushing...im used to diffs with crush sleeves, and this one doesnt work that way...
Old April 22nd, 2016, 10:48 AM
Yes they will. Look closer at how it works.
Old April 22nd, 2016, 10:53 AM
Here is the cross section. Perhaps it will be clearer. The manual is very clear and takes less time to read than me typing this post....
Old April 22nd, 2016, 11:05 AM
Gabriel_Laconi
Gabriel
1992 Rangge Rover
Which shims are we talking about? The ones under the inner bearing race? Or the ones between the pinion and outer bearing? If we are talking about the ones under the inner bearing, ill be throwing the whole thing away...
Old April 22nd, 2016, 11:16 AM
I give up.
Old April 22nd, 2016, 11:25 AM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
read this:
Differential Installation Instructions | West Coast Differentials
Old April 22nd, 2016, 11:27 AM
Gabriel_Laconi
Gabriel
1992 Rangge Rover
Originally Posted by Red90 View Post
I give up.
Look, im really sorry im not up to your level of expertice. I find myself in need of help, if you just have this urge to be an ass just move along, ok? I know you are frustated by noobs, but imagine how i feel not knowing what to do and on top having to deal with your condecendig comments.
Old April 22nd, 2016, 11:32 AM
Read the manual. It is simple and clear there and is all of two pages. You do not need us to write out the manual for you. Land Rover did that for you.
You come on here asking for help. It is given and you disregard the help given and then complain and continue asking the same questions that have been answered. Read the manual FIRST. If it is not clear then ask for clarification.
Old April 22nd, 2016, 11:46 AM
Gabriel_Laconi
Gabriel
1992 Rangge Rover
I have the manual. I read it, i set the diff. If i tighten the pinion nut "very tight" the pinion binds up. So what i need to know is just WHAT is "very tight" im sure there has to be a value out there, i just cant find it on the manual. I heard 100 ft/lbs online, pinion WILL NOT move if its that tight...
Old April 22nd, 2016, 11:51 AM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
Are you installing any shims and proper torque…all the info you need is in the manual
if you torque to spec and it doesn't move, your pre-load is fucked
Old April 22nd, 2016, 11:53 AM
Pinion nut torque is 70 to 120 lb-ft.
This is the instruction for setting bearing preload. The shims are at location 54 in the sketch above. You torque the nut. If the preload is too high, you install a thicker shim and try again. Keep changing shims until the preload is correct.
Section 51, page 7.
58. Tighten the pinion flange nut to the specified torque (see section 06-Torque values). The force required to rotate the pinion shaft should be within 23 to 40.25 kgf cm (20 to 35 in lb) using new bearings, when initial inertia has been overcome. Change the bearing pre-load shim as necessary to obtain this requirement. A thicker shim will reduce pre-load; a thinner shim will increase pre-load.
NOTE: If using original bearings, which are bedded in, the pre-load figure is 11.5 to 17.25
kgf cm (10 to 15 in lb)
Old April 22nd, 2016, 12:05 PM
Gabriel_Laconi
Gabriel
1992 Rangge Rover
Section 51, page 7.
Thats more like it. I finally have a value to go by. Sucks i need more shims, but at least i know what im looking for. Thank you.
------ Follow up post added April 22nd, 2016 12:08 PM ------
I was reusing the original shims and they seemed so thick i was hoping they were still ok...
Old April 22nd, 2016, 12:27 PM
Gabriel, when you said, "I have the manual. I read it, i set the diff" it seems a bit odd when John just copied and pasted the manual you claim to have read, and you all of a sudden have a revelation.
Whether you realize it or not, it takes time and effort for people to do work for you.
It's clear that you didn't read the manual, and you just straight up gave a middle finger to everyone in this thread who told you to read the manual. Think about that.
That said, I don't think you have any idea how to set up a diff. Since it's obvious now that you haven't actually read the manual (looking at words is not considered reading), I suggest you go back and make sure you set the carrier bearing tension, diff gear contact pattern, and pinion preload correctly with an in-lb torque wrench.
If you do not do these, your diff is pretty much lunch. If you say you already did, I doubt you, since it's obvious you didn't read the manual.
Old April 22nd, 2016, 12:47 PM
Gabriel_Laconi
Gabriel
1992 Rangge Rover
The revelation came from an actual torque value and location of shims that need to be replaced. None of which are specified on the manual. If i dont know what "preload shims" are, i will not understand, just reading the manual, where they are located. The "preload shims" on my pinion are more like thick ass washers, so i consider them more like spacers. I didnt know what they were called. I apreciate the help, but if you have no time, dont feel obligated...
differential
Differential Craigd Defender Technical Discussions 5 April 22nd, 2007 08:56 PM
SG winch bumper, GKN torque limiters, OME 751 springs Shane@EVS For Sale - Parts 24 June 1st, 2006 02:37 PM
torque flippedrover Defender Technical Discussions 12 May 21st, 2004 01:03 PM
New differential questions... wicks Defender Technical Discussions 15 May 5th, 2004 11:39 PM
Differential with 5 k miles on it for sale. PhilDes For Sale - Parts 0 January 28th, 2004 09:21 PM
