Differential Ratios - Defender Source
Old January 6th, 2007, 10:50 AM
gearco
James T. Johnston, Jr.
1986 D110
Differential Ratios
Anyone know if the differential ratios on a Euro 2004 TD5 are the same as on a NAS 1997 D90? If they are different, do you know what each one is? Considering a swap of sorts and need to know. Thanks.
Old January 6th, 2007, 11:28 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
If you are considering swapping both axles, it does not matter (your speedo might be off a little, power/acceleration/... might be slightly affected). I can probably check the workshop manuals and see what they say.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old January 6th, 2007, 11:50 AM
gearco
1986 D110
No, I'm thinking about using a 4 valve per cylinder gasoline V8 with the TD5 diffs. The truck will be mainly used on the highway and I don't want the diffs to be geared too low. If you have a reference that will tell you the ratios I'd appreciate your help. Many thanks.
Old January 6th, 2007, 11:54 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
The 2004 Td5 runs the same 3.54 ratio as a US D90/D110. That ratio will be fine on the highway unless you install some large tires.
Email:
Old January 6th, 2007, 12:13 PM
gearco
1986 D110
That's exactly what I was looking for. Many thanks.
differential
Differential Craigd Defender Technical Discussions 5 April 22nd, 2007 08:56 PM
Gear ratios - 1995 NAS Defender? jam90 Defender Technical Discussions 3 February 19th, 2006 03:58 PM
rear differential gasket ?? jstrong98 Defender Technical Discussions 5 May 13th, 2005 08:28 AM
New differential questions... wicks Defender Technical Discussions 15 May 5th, 2004 11:39 PM
Differential with 5 k miles on it for sale. PhilDes For Sale - Parts 0 January 28th, 2004 09:21 PM
