differential noise - Defender Source
Old June 29th, 2014, 11:18 AM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
differential noise
Posted earlier about vehicle not moving from stoplight, eventually moved with rough rumbling sounds from front end. Could have been CV joint, u-joint, front prop shaft. Vehicle towed home.
Today I jacked up the front end, one side only. Transmission neutral, separated prop shaft. Rotating tire with hand, rough noises seem to coming mostly from near drive flange area rather than pinion gear (used stethoscope to test). Going to disassemble further but any thoughts? Is the pinion bearing shot? Maybe it is the pinion gears?
See video and pic.
Old June 29th, 2014, 11:32 AM
CaptMidnite
Daniel Choi
In case video doesn't play, Youtube link:
Old June 29th, 2014, 11:55 AM
Keep digging! We all may learn something from this.
Old June 29th, 2014, 11:36 PM
Well if you pull the diff, you will see both CVs and the diff. Easiest solution is to swap in a good used diff.
differential
Differential Craigd Defender Technical Discussions 5 April 22nd, 2007 08:56 PM
3 oil spots under center differential {...} ini88 Defender Technical Discussions 3 September 27th, 2006 03:46 PM
rear differential gasket ?? jstrong98 Defender Technical Discussions 5 May 13th, 2005 08:28 AM
New differential questions... wicks Defender Technical Discussions 15 May 5th, 2004 11:39 PM
Differential with 5 k miles on it for sale. PhilDes For Sale - Parts 0 January 28th, 2004 09:21 PM
