Differential - Defender Source
Old December 8th, 2003, 03:55 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
Differential
I don't have a very good service manual so maybe someone can help. Where the rear driveshaft connects to the rear differential I am getting a small leak at the flange between the yoke and differential. Is this an expensive fix, and since the leak is very small can I just add oil to the rear diff as needed?
For what is worth I have 133,000 miles and this is my first leak, so I feel very lucky so far.
Old December 8th, 2003, 04:26 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
its an easy fix. You just need the new seal socket to fit flange nut and a torque wrench. Pry out the old seal, install the new one, install flange with bolt and torque to spec. Done.
Legend in My Own Mind.
Old April 21st, 2007, 11:55 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Sorry to bring back an old thread, but does anyone have a part number for the seal? Mine just started leaking. Possibly a link to order?
Thanks, Chris.
Found one: http://www.roverparts.com/Parts/FRC8220.cfm
Just want to make sure it's the right one.
Old April 22nd, 2007, 01:27 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
That one will work fine for you it's what I have run for years in my Classic.
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old April 22nd, 2007, 02:31 PM
cellulararrest
Chris Snyder
Will that work for both the front and the rear? Front's leaking a bit too.
Thanks!
Old April 22nd, 2007, 08:56 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Yep that will work front or rear.
Good luck
Eric
Eric Riston
differential
FREE: D90 Front Drive Shaft and Differential Guts coryhula For Sale - Parts 3 January 6th, 2009 03:54 PM
3 oil spots under center differential {...} ini88 Defender Technical Discussions 3 September 27th, 2006 03:46 PM
rear differential gasket ?? jstrong98 Defender Technical Discussions 5 May 13th, 2005 08:28 AM
New differential questions... wicks Defender Technical Discussions 15 May 5th, 2004 11:39 PM
Differential with 5 k miles on it for sale. PhilDes For Sale - Parts 0 January 28th, 2004 09:21 PM
