Different T-case Noise??? - Defender Source
Old February 9th, 2008, 06:19 PM
Bud
BRANNAN FELDT
NONE
I am new here, and yes I did read the other threads to rule out my problem. So here we go...
I am working on my buddies 94 D-90 w/ auto and the t-case makes a terrible ratcheting noise when going fast and you let off of the gas. I pulled the rear driveline and it went away. I fixed a u-joint going bad in the rear driveline, put the driveline back in, and it's still there. I even grinded out some of the material on the upper part of the rear driveline to make sure it wasn't binding up. I cleared the material enough to allow it to rotate freely at full drop on a lift. At the same time I pulled the PTO cover off and pulled the input gear out. It looked good on the tailshaft and inside the input gear, the edges of the splines are still nice and sharp. The larger gear on the outside of the input gear had some wear on the teeth, but nothing too severe. There is no play on the tailshaft of the trans or or the t-case. PLEASE help!!!!
Bud
Old February 10th, 2008, 09:13 PM
Bud
BRANNAN FELDT
NONE
Any help here???
Old November 11th, 2008, 03:30 PM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
I have the same problem. It only happens when I am on the highway and let off the gas. I noticed that it happens after driving for a while, starts of quietly and gets louder. If I jump right on the highway, it doesn't do it for a few miles.
T-case and lt77 were rebuilt 300 miles ago(not for this reason). It did before the rebuild also.
Old November 11th, 2008, 03:42 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
If you pulled the rear drive shaft and it went away its not your T-Case. Look at the diff
3rd low and BOOT IT
Old November 11th, 2008, 03:47 PM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
It happened with the old gears(3.54) and the new ones(4.11), that's why I didn't think it was the diff.
Transfer Case Noise Andrew Vick Defender Technical Discussions 10 September 12th, 2007 11:02 AM
Noise from engine--curse of my existence Davis Defender Technical Discussions 25 June 24th, 2005 04:27 PM
Curious knocking noise mikeslandrover Defender Technical Discussions 6 March 29th, 2005 06:09 PM
LT230 noise? Chaucer Misc. Chit-Chat 5 March 19th, 2005 02:59 PM
whistling noise from engine jstrong98 Defender Technical Discussions 2 December 14th, 2004 11:37 PM
