Different swivel balls? - Page 2 - Defender Source
Old September 12th, 2012, 10:52 AM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Originally Posted by o2batsea View Post
You don't need pics or measurements. The top pin is either a Railco bushing or a tapered roller bearing. There is no mistaking the two. Railco bush type swivel has a bore that goes straight all the way thru the top of the casting. The bushing has a shoulder that sits on the machined surface of the swivel housing. Tapered bearing type has a seat for the outer race.
Yup thats what I gathered from looking at diagrams of both. ABS using same part number bearing top and bottom and non abs uses a different bearing up top i.e. roller bearing.
If there is no race in the swivel ball is it still going to be obvious?
Thanks for the pics Jeff
Old September 12th, 2012, 01:43 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Ok so is it safe to say this is an ABS indicated on the flange?
ID:	57509   Click image for larger version
Old September 12th, 2012, 02:19 PM
ABS uses the Railco bushed swivels cz the ABS sensor pokes down thru the hollowed out pin. I may be mistaken, but I do not believe there is anything like a top roller bearing (small pin) swivel that's ABS.
Old September 12th, 2012, 02:43 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
I dont follow?
From what I have gathered
ABS uses this bearing up top http://www.roverparts.com/Parts/FTC2065.cfm?gpf which sits between two washers in the housing on that lip beneth the swivel pin
The non abs style ueses these top AND bottom http://www.roverparts.com/Parts/606666.cfm
Not sure where the railko bushing is coming in? I know series trucks use railko bushings (http://www.roverparts.com/Parts/443.cfm)? Or maybe I am stupid and thats what I call washers?
Resurfacing swivel balls jefhuf Smaller Projects 28 September 27th, 2016 04:12 PM
Replacing bearings, found swivel balls empty Broncoduecer Defender Technical Discussions 30 December 2nd, 2011 01:46 AM
Hard Chromeing swivel balls pendy Series Technical Discussions 4 February 28th, 2011 09:37 PM
re-drilling the swivel balls slorocco Truck Build-up's & Restores 15 November 17th, 2008 11:44 AM
swivel balls what to do when pitted and why are 110 swivels so expensive draaronr Defender Technical Discussions 3 August 29th, 2004 07:35 PM
