different noise - Defender Source
Old September 19th, 2006, 03:35 PM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
different noise
I have this very aggressive rattle and violent vibration in the drive train at low RPMs in first and second gear, and again while slowing down at aquivalent speeds. Inland Rovers is thinking the rear differential, but I would think that if it were the rear differential it would be constant, as opposed to just at one speed. I can`t for the life of me figure out where it is comming from, but anyone got any ideas on what I should check? I was planning on dropping out the rear drive shaft and driving it to see if it still does it without the rear differential, but is there anything else I could easily test? Any ideas would be awesome
Old September 19th, 2006, 03:44 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Does it do it in low range or with the t-box in neutral? 3rd or 4th gear? Reverse? pull the plugs, is there a lot of metal in any of the gear units? Has anything run out of oil? Does the noise change as the load changes? Run it on a wheel free hoist and listen to the gear units with a stethoscope. If it's that loud it won't be hard to track down.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Noise from engine--curse of my existence Davis Defender Technical Discussions 25 June 24th, 2005 04:27 PM
lifted d 90 noise 4x4x46 Defender Technical Discussions 11 June 15th, 2005 07:29 PM
Curious knocking noise mikeslandrover Defender Technical Discussions 6 March 29th, 2005 06:09 PM
LT230 noise? Chaucer Misc. Chit-Chat 5 March 19th, 2005 02:59 PM
whistling noise from engine jstrong98 Defender Technical Discussions 2 December 14th, 2004 11:37 PM
