different ignition options - Defender Source
Old December 3rd, 2003, 01:09 PM
vesparover's Avatar
vesparover
brian bertolini
hey everyone, I'm in the process of reinstalling the dash that i ripped apart -when i thought my ignition had gone bad. It ended up being another relay related problem. So, I really don't want to reinstall the stock switch because it looks like it's on the way out as well. A new ignition costs 200, but I've never heard anything good about these things. I'm thinking about a push button starter with a key. Anyone else running any thing other than stock?
thanks
brian bertolini
Old December 4th, 2003, 05:10 PM
vesparover's Avatar
vesparover
brian bertolini
is everybody using the stock key ignition??
brian bertolini
Old December 4th, 2003, 09:01 PM
I don't think it would be too hard, but it would have the bling effect . I was just at the auto store and they had push start ignition stuff on the shelf. The button looked to be about the size of the key slot. I don't know if it had a key switch though, you could always use a switch and hide it inside your Tuffy box (chubby box) so that you can lock it off.
Old December 4th, 2003, 09:07 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I'm with Mike, it would probably not be that difficult but the problem would come with the power take offs. The switch operates many different features that an aftermarket switch would not address. The switch itself can become loose and the key can wear down but it is a stout unit. I don't think that you need to replace it. just my .02
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old December 4th, 2003, 10:44 PM
vesparover's Avatar
vesparover
brian bertolini
ya, I was worried about being a little ghetto looking. I figured I could have a key to operate everything but the start function- but I haven't found one like that. I'm sure I'll just put the stock unit back in tomorrow.
brian bertolini
Old December 5th, 2003, 03:02 PM
read's Avatar
read
Read Kerlin
'94 w/ POE HT
is it the electrical contacts that are going or the lock-set? if it's the electrical switch, you can replace it at a fraction of the whole setup. about $30 as I remember.
Insert pithy quote here.
Ignition? Trigger Defender Technical Discussions 12 August 1st, 2005 08:53 PM
exhaust- options Nigel Defender Technical Discussions 11 October 20th, 2004 10:34 PM
Ignition Relocation = No Start...Help JRowe Defender Technical Discussions 5 March 8th, 2004 12:45 PM
Ignition Module Relocation: Help JRowe Defender Technical Discussions 21 March 7th, 2004 11:45 AM
