Different engine temp question, I've searched - Defender Source
Old October 21st, 2007, 09:04 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
With my 2.25 my "normal" operating temp was around 3/4 of the way up the normal range of my Series III. Has anyone ever measured at what temp the "Red Zone" on the guage is it? I am now running a Daihatsu diesel with a higher temp thermostat so it appears I climb to high temps under load but since this motor runs a 82 or 88 degree celcius thermostat it is tough to tell vs. the 74 and 82 degree rover thermostat. I'm still using a rover sender and rover guage. Do the infrared non contact temperature readers give pretty close readings if I just point it at the water outlet or top of the radiator. I suspect the Diesel just runs hotter under load, during easy going driving it stays bellow where the 2.25 ran.
Old October 21st, 2007, 11:19 PM
pendy's Avatar
pendy
jim pendleton
89'd90
For gosh sake put a real tempurature gauge on the thing. Egauges.com has VDO gauges inexpensive with numbers to track temps. I believe its rather important.
JP
legend in my own mind
Old October 21st, 2007, 11:39 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
EGT too.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 22nd, 2007, 09:22 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
JP
Sounds like a plan.
Anyone sure of the thread size for a series sender?
Old October 22nd, 2007, 12:48 PM
5/8-18 UNF
buy a bolt of that size to double check but I am 99% sure.
rgrds
dave in dc
Originally Posted by KevinNY
Sounds like a plan.
Old October 22nd, 2007, 01:10 PM
Michael
Michael
Discovery 1998
Murhpy Swichgages are nice too, and they have a manually set switch that grounds - can be used to activate buzzer, light, or both. more expensive though.
thats Murphy
Old October 22nd, 2007, 03:18 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Confirmed it with a new sender, 5/8-18. The sender at Egauges is part #323-026. Also shot some temps with an IR reader. Half way up the series gauge driving around town the water outlet base is about 150 degrees, after a highway run 190 degrees, inlet pipe of radiator read 200. 200 would correspond with the beginning of the red on a series III gauge. I ordered the 250 degree VDO guage #310-105.
engine
Engine Temp issues sflash868 Defender Technical Discussions 11 May 25th, 2005 04:51 PM
Engine Oil Leak Question ronward Defender Technical Discussions 0 March 22nd, 2005 09:38 AM
Snorkel question searched and came up empty rustydefender Defender Technical Discussions 12 October 30th, 2004 05:43 AM
Engine Temp - Normal range mgrgpg Defender Technical Discussions 5 June 10th, 2004 08:47 PM
