differences in Defender / disc front end ? - Defender Source
Old October 3rd, 2010, 05:26 PM
Chris Velardi's Avatar
Chris Velardi
Chris Velardi
1975 101FC
I'm wondering what or if there are any differences in the 1997 Defender and the the 1997 Discovery front ends?
So if I were to take the front axle and steering box off the disco would there be any issues fitting it to a Defender ? And if they are exactly the same what other year discos would be the same ?
Chris "V"
Old October 4th, 2010, 05:02 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
The only difference on the axle is the smaller calipers on the Disco front end and the rotors of course. NAS 90's had vented rotors during that time ROW trucks did not.
The only difference between the steering is the Defender Pitman arm and drag link. The Deefer has the Damper mouted up front the Disco has no facilities for that.
Keith
Big, Red and ... aaa Red..
Old October 5th, 2010, 12:37 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Check to make sure wether the swivels are Chrome or Teflon (black). My 96 D1 has Chrome, my 97 D90 has Teflon and my 98 D1 has Teflon. So the Discos changed over some time in 97. Teflons are much better in my opinion (no pitting) but you can only use grease not oil in the swivels as there are no drain plugs on the Teflon version hubs.
Old October 5th, 2010, 02:56 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I thought the only difference was the coating on the swivel ball. That either would work with either housing.
When did D90's get ABS? that would be the other difference, though I can't think of any reason you couldn't use an ABS axle assembly on a non-ABS vehicle.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old October 7th, 2010, 12:06 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
97 NAS D90s have a rough road system. It's not ABS as it doesn't have any connection to the brakes but it has the speed sensors at the wheels so its an ABS axle.
Yes the Teflon is just a coating, but it seems to last much better than the chrome so might be something the OP wants to keep. Not sure without checking if the seals and stuff are different or not. Changeover happened sometime between 96 and 98 on the disco. Not sure when.
94 NAS Defender 90-P.O.E.(Port of Entry) 1 of 65 made! on EBAY SeanD-90 Misc. Chit-Chat 29 May 27th, 2017 08:14 AM
1997 Disco Front end upgrade tomaco1 Defender Technical Discussions 2 November 23rd, 2009 10:25 PM
Modified 1995 Defender 90 jdb3760 For Sale - Vehicles 23 April 21st, 2009 09:40 PM
Something Wrong With The Front End? The Wizard Defender Technical Discussions 13 October 4th, 2006 11:51 PM
How to replace front shocks in Defender? wicks Defender Technical Discussions 8 October 7th, 2003 12:08 PM
