Difference in these tops? - Defender Source
Old November 12th, 2012, 09:18 PM
todd022
todd
none
Please move if I've incorrectly posted...I'm looking at these two D90's (one is a 1994 and the other a 1995), and curious about the difference in tops, if any? I'm definitely a fan of the hard top, but would still like to be able to remove it. Which of these two tops is made to be removed? Or are they the same, and I'm going crazy. Thanks! Hope to be joining the defender ranks in the coming weeks.
ID:	60788   Click image for larger version
Old November 12th, 2012, 09:20 PM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
the first picture is removable. its a fiberglass top. the 2nd picture is still removable but a lot harder.
Old November 12th, 2012, 09:22 PM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
The first one is a fiberglass top that is meant to be removed. The one one the right can be removed but is meant to be more permanent.
Old November 12th, 2012, 09:25 PM
todd022
todd
none
Amazing fast! No BS answers, thank you!
Old November 12th, 2012, 09:30 PM
Those two trucks appear to be in two totally different price ranges. If the seller hasn't already told you, the 1994 is a soft top defender 90 with a fiberglass hard top fitted to it - a canvas soft top can replace the fiberglass hard top (that's what that black strip below the rear windows is for). It should have a full soft top cage fitted underneath that top. If it does not, then it should be drastically discounted as they are difficult to source. I can at least see the diagonals in the rear windows.
Either way, the 1995 hard top appears to be priced significantly higher than the 1994.
Defender Doors and Door Tops Buckon37s For Sale - Parts 5 June 12th, 2005 06:14 PM
Soft Tops for sale: 4WD-90 For Sale - Parts 4 May 24th, 2005 06:49 AM
Dual Yellow Tops in Parallel ronward Defender Technical Discussions 12 March 28th, 2005 02:39 AM
Soft Tops TheKoz Defender Technical Discussions 2 March 23rd, 2005 02:47 PM
'95 Yellow D90 ST w/ 3 tops dalesmith71 For Sale - Vehicles 10 March 19th, 2004 09:59 AM
