Difference in pitman arms? - Defender Source
Old July 18th, 2011, 11:04 PM
DesertRat
Bryan Barnes
95 D90 2.8TGV
Is there a difference between right hand drive and left hand drive pitman arms? Bought a
pitman arm and rebuild kit from this board for a great price. The new (to me) pitman arm is about
1/2" longer than my old one. That in itself probably wasn't a bad thing, but I think the spline
keyways may be at a slightly different angle. I can't get sh*t to line up now with the steering.
The drag link is the same length as before but the steering wheel is 90 degrees off. I'm about ready
to yank the rebuild kit out of the new arm and go back to the old arm. The only reason I didn't do
that to start with was because I kind of boogered up top of the old one trying to get the drag
link loose. Seems like nothing is ever simple.
Bryan
BTW....I'm just guessing about the left and right hand thing, it wasn't advertized that way.
Old July 19th, 2011, 12:43 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Replace the pit-man arm with one off a D1 and then the part replacement is much easier after that.
Pitman arm to Steering box question dmarchand Defender Technical Discussions 3 September 5th, 2008 11:53 PM
Need new drag link & pitman arm !? Rover- Girl Defender Technical Discussions 4 March 23rd, 2006 06:33 PM
Rear Trailing Arms Joe P Defender Technical Discussions 7 July 16th, 2005 11:36 AM
Used D90 Radius Arms Northface Wanted 3 March 29th, 2005 08:42 PM
Difference in frames between Disco/110? fpkelly Defender Technical Discussions 32 January 6th, 2005 02:45 PM
