difference: Disco 200tdi and Defender 200tdi? - Page 2 - Defender Source
Old May 20th, 2004, 03:41 AM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Ah, ok, that makes sense (why there is a problem) though it must look strange to have the exhaust manifold on top and intake below..bizarre. I'd like to see a pic of that. Here's a pic of the engine on Ebay (believed to be from a Disco, sounds like it is from what you describe):
*******http://www.roversland.com/ebay/200TDi/f4.JPG*********
So, you really need both intake and exhaust manifolds together to 'convert' a Disco 200tdi to a Defender-installable engine.
Someone on a message board somewhere had definitely stated that the 200tdi was a stronger engine (if less powerful). *shrug* I have heard of the timing belt issue, though.
Old May 20th, 2004, 04:11 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
You wanted pics
Here's the turbo
Mike Hammond
Old May 20th, 2004, 04:14 PM
mikeslandrover
Mike Hammond
This is the Disco engine from Ebay
Mike Hammond
Old May 20th, 2004, 04:20 PM
mikeslandrover
Mike Hammond
The turbo is in a completely different place, one of my mates fabricated a new exhaust from the turbo with some pretty sharp bends in it bud i think the steering would get in the way. You can see on the defender engine the turbo sits above the rocker cover, its still a close fit around the bulkhead
Mike Hammond
Old May 20th, 2004, 04:23 PM
mikeslandrover
Mike Hammond
Here's a shot of the injection pump on my defender, not the same as a N/A diesel
Mike Hammond
Old May 20th, 2004, 04:26 PM
mikeslandrover
Mike Hammond
Here's a close up of the turbo & heat shield
Mike Hammond
Old May 20th, 2004, 04:29 PM
mikeslandrover
Mike Hammond
any other shots you'd like (short of taking the engine out)?
Mike Hammond
Old May 21st, 2004, 06:08 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Thanks Mike. That's pretty revealing. That has to be the weirdest location for a turbo I've ever seen. I can't think of another engine which routes it's exhaust manifold above the intake manifold!
Heh you'd think the heat would melt the paint on your hood
Old May 21st, 2004, 06:35 PM
mikeslandrover
Mike Hammond
Having the turbo up there keeps it away from water when wading ridiculously deeply.
The whole engine bay runs much cooler than a petrol engine. No cooking eggs on the bonnet
Mike Hammond
Old June 3rd, 2005, 06:18 AM
Chris M-110's Avatar
Chris M-110
Chris Visser
110 HT
Hi, I'm Chris, i'm from The Netherlands and I own a military '89 2.5na 110 (Royal Dutch Marines).
In the Dutch-LR-scene, the disco-2300tdi-upgrade is often discussed and I know of several people performing the swap, so it is defenately possible. I am planning to do the engine-swap in september. here's what i know about it:
The Disco's turbo is positioned higher and switching it for a Def in-and outlet and turbo, is extremely pricy. Having LHD-vehicles in Holland too, there is not enough room on the left-hand-side of the engine.
One way of dealing with the space-problem is turning the turbo one quarter and using a Saab-900- exhaust-pipe (only the first bit, the bend). U have to fiddle a bit with it, but it does seem to work.
As soon as I have pictures or a more detailed discription, I'l let you know.
BTW the exhaust-diameters are different, so you'l need to replace the entire exhaust
Toedeloe,
ps: have a look at my website: www.opwielen.nl (just follow the Land Rover)
Old June 3rd, 2005, 10:10 AM
Chris M-110
Chris Visser
110 HT
I've found a Brittish website about fitting a Disco 200tdi in a Defender (TD).
http://www.muddy-tyres.net/200conv.asp
keep in mind that the steering is on the wrong/right, hmm, .. opposite site
Toeleloe
Chris M-110
200tdi, disco, tdi
Disco 200Tdi Alternator P/N? newfD90 Defender Technical Discussions 8 January 29th, 2012 07:29 PM
200tdi air filter mounting bracket (defender) dave_lucas Wanted 2 December 4th, 2009 08:26 PM
Defender 200tdi wastegate / boost tee location dave_lucas Defender Technical Discussions 9 November 18th, 2009 04:18 PM
Defender transmission for 200tdi mattm Wanted 7 October 9th, 2009 10:30 AM
1991 RHD - Defender 90 Station Wagon - 200tdi AUTO - CDN$18,000 globallandrovers The Vendors Loft 0 March 4th, 2009 08:39 PM
