Difference between Battery Boxes ... - Defender Source
Old November 25th, 2012, 11:52 AM
the part listed for a NAS is MXC8556 and you'd think it were made of gold ... as its around $1000 the later part is about $100 ... can the later part be made to fit or should i just go with a YRM version?
Old November 25th, 2012, 12:10 PM
Go for YRM. Very impressed with their product.
Old November 25th, 2012, 12:13 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Yeah its a bit much but I would go with YRM also. Good stuff ain't cheap!
Old November 25th, 2012, 01:12 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
battery box
I did notice that RN has a battery box (RNS340) listed at $96
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old November 25th, 2012, 01:59 PM
sro
Sam Odio
2008 LR2
Can someone explain to me why one should not just set the battery in the under-seat compartment without a box? I must be missing something.
Old November 25th, 2012, 02:22 PM
Yeah that's the bit I'm looking at. But it's for later models. I want to know if it fits.
Old November 25th, 2012, 02:46 PM
spartan's Avatar
spartan
Fred
83 D110
I just installed the battery box from RN. It was a genuine/OEM LR part. Pretty good price if you need the left side. If you need the right side box YRM is the way to go. YRM also sells the side panels.
Old November 25th, 2012, 04:35 PM
Was that the $95 battery box?
Old November 25th, 2012, 04:37 PM
spartan's Avatar
spartan
Fred
83 D110
Yes. It had a land rover decal and was powder coated or e-coated black.
Old November 25th, 2012, 04:55 PM
Old November 25th, 2012, 05:28 PM
spartan's Avatar
spartan
Fred
83 D110
here is the pic. I powdercoated it white
Old November 25th, 2012, 05:37 PM
Did you powder coat the whole seatbox?
Old November 25th, 2012, 05:44 PM
spartan's Avatar
spartan
Fred
83 D110
yes, im powdercoating everything I can. I would do the whole truck but it needs too much body filler.
Old November 25th, 2012, 06:08 PM
Holiday's Avatar
Holiday
Ross Simpson
1995 D90 ST/2006 D3 HSE7
I've got the same project going on in my garage. Surprised to hear that you've gone with an OEM battery box, and YRM utility. Isn't the reason that the OEM's rust so badly in the first place is that they're dissimilar metals (steel vs. aluminum), leading to galvanic corrosion? It's unfortunate LR chose to use the cost saving, rust promoting aluminum for construction of the seat box.
I'd prefer to use the OEM pieces over the thinner (2mm) aluminum that YRM uses too, but the galvanic issue has convinced me otherwise. I have an order in for both YRM pieces.
Old November 25th, 2012, 06:14 PM
spartan's Avatar
spartan
Fred
83 D110
I powdercoated both the steel and aluminum pieces. I think this will last a long time before corroding. My biggest complaint is that the original steel battery box rusted because of the poor quality paint from Land Rover.
I did not use any YRM parts. I made them at my shop. If I had a chance to do it again I would buy it from YRM.
battery
Battery Box Redux chris snell Smaller Projects 31 January 9th, 2016 03:34 PM
Battery Compartment under seat Flagg Defender Technical Discussions 11 May 15th, 2007 11:38 AM
Sealed battery? OCD90 Defender Technical Discussions 4 December 22nd, 2003 01:43 PM
