Difference between 2000 and 2001 Defender 110 TD5? - Defender Source
Old July 24th, 2015, 06:52 PM
WestCoastRover's Avatar
WestCoastRover
Jeff
2000 TD5
Red face Difference between 2000 and 2001 Defender 110 TD5?
I know there were big changes between the model year 2000 and 2001 (parts are often different).
To import Defenders to Canada they must be 15 years old. I am wondering what I will gain if I wait a few months and get a 2001 Defender 110 TD5, I will be putting thousands into the build. I currently own three 2000's!
Thank you for the help guys!
Old July 24th, 2015, 08:04 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
You should wait and get a late model '02 model. That has the 15P engine instead of the earlier 10P which has issues with the head. ECU is different too. Plus, the'02 has the nicer dash.
You could bring in an '01 already. The importation law at 15 years, is actually to the date of manufacture, not year model. My 2000 Td5 was brought in September of last year, as it was actually manufactured in August of 1999. The vin sticker (should be on the left wall of the drivers toe box) will show the actual date it was made.
Old October 16th, 2015, 05:09 PM
WestCoastRover
Jeff
2000 TD5
Hm, haven't located this sticker yet. I was under the impression you could only find the Manufacture Date by calling Land rover. Big news if this is not the case. Do you have a picture?
In LATE 2001 models (but Still a 2001), It seems you have the better dash/command console. And I assume the better TD5 as well. Late 2001 has the single stamped rear door to.
Other than the new style rear circle Fog/reverse lights.. is there any differance from an EARLY 2001 (No dash, No rear door) and a 2000 model?
Ps, Hi Scott!
Old October 17th, 2015, 12:28 AM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Hi Jeff. That sticker is only on the NAS models. For ROW search the VIN on VIN decoder is the best online tool to check vin number | VinDecoderz.com usually pretty accurate as far as year model and year of manufacture. If you have access to Microcat you should be able to get the actual build date.
110, 2000, defender, defender 110, td5
Whats the difference between a US 1993 110 and a Canadian 1993 110? jjstahl3 Misc. Chit-Chat 2 April 19th, 2011 12:33 PM
Difference between TDi R380 and V8 R380? turbodave Defender Technical Discussions 5 July 19th, 2008 06:15 AM
LT230 - difference between auto and manual? jaherring Defender Technical Discussions 3 February 8th, 2008 11:17 PM
Difference between "WOLF" and "NATO" wheels? wicks Defender Technical Discussions 10 August 12th, 2005 04:23 PM
Help wanted: Difference between RR 2.5 TD and 2.5 DSE lakis Defender Technical Discussions 0 November 17th, 2004 10:23 AM
