Diff Oil coming out the drive flanges - Defender Source
Old June 8th, 2015, 02:02 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Did a long drive on the highway this weekend in some pretty hot weather. At the gas station, I noticed a little oil around both rear drive flanges. Kept driving and when I got home the entire rear driver rim was soaked in gear oil and the passenger was wet as well but not nearly as bad. I had replaced my axles with HD ones from GBR and resealed the flanges 800 miles ago so everything was fresh. It's not on the back side of the hub, so not coming out the hub seal. It's actually pushing out through the bolt holes in the flange and around the edges, through the silicone seal.
My thought here is it might be the axle breather since it started happening on both sides simultaneously but I've always thought the "blocked breather" thing was kinda BS so figured I'd post to get some advice. As I recall, there is also an internal seal on the back of the stub axle. Should I assume they are shot on both sides?
Old June 8th, 2015, 02:06 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
I'd be checking my drive flange bolts and using red LocTite on them.
Old June 8th, 2015, 02:14 PM
I'd definitely check the breather for blockage. I can't think of a reason why the bolts would spuriously weep so furiously on your rears.
Old June 8th, 2015, 02:15 PM
Naplm00
Matthew
I would not use red loc tite. I would use thread sealant for engine building. It is designed to keep oil from coming up the the thread of oil galley plugs.
http://www.summitracing.com/parts/arp-100-9904
I use this stuff on all the plugs and threads on my vehicles that need to hold oil, especially fill and drain pipe plugs
that or you have a bad inner hub seal
Old June 8th, 2015, 02:32 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Would a blocked breather really generate so much pressure to push oil through the inner hub seal, past the bearings and grease, through the RTV and out?
My other thought.. the GBR axles are thicker than stock. Could the thicker shaft diameter have ruined the inner seal somehow? If memory serves correctly, the stock shafts bulge around the seal and then taper so i didn't think to change the seals when I swapped axles
Old June 8th, 2015, 02:36 PM
It's possible...but the only two places I can think of that would allow oil leaking from the stub seal to evacuate are:
a. The hub seal
b. The flange seal
If the leak is on the inside of the wheel, then it's quite possible that it's the hub seal. One mistake I made when installing my hub seals for the first time was not driving them into the hub as far as possible. This caused the lip of the seal to contact the stub and literally tear in half.
The flange seal seems unlikely to leak, at least not at the rate that you're describing.
Have you change the hub seal recently?
Old June 8th, 2015, 02:44 PM
rovertrader's Avatar
rovertrader
Dale
Heat = pressure
Old June 8th, 2015, 02:47 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Let me rephrase.
Check you drive flange bolts to see if they're loose. I use red LocTite to keep the bolts tight, not to keep them sealed. An inner axle seal won't cause leaks.
oil leak(s) coming from my drive train michael15 Defender Technical Discussions 24 September 15th, 2005 10:28 AM
Rovertracks HD front axles CV's & GBR drive flanges ToaDisco For Sale - Parts 8 July 4th, 2005 01:50 PM
Maxi-Drive Flanges p/n MDE859 Roadsiderob For Sale - Parts 5 January 30th, 2005 09:33 PM
Rear HD Maxi-Drive Axles and Drive Flanges lwg For Sale - Parts 1 January 3rd, 2005 03:51 PM
GBR heavy duty drive flanges jorge Defender Technical Discussions 2 February 29th, 2004 11:51 PM
