Diff Lock won't engage - Defender Source
Old July 9th, 2007, 09:32 PM
61rover's Avatar
61rover
John Crouse
Previous owner probably NEVER used it (or knew what it was). Where should I start in getting it freed up?
Old July 9th, 2007, 10:25 PM
LRover's Avatar
LRover
J. Michael McCaig
The good news is it's probably just frozen linkage. Get some really good penetrating oil and hit every joint, it may tak a while. You can get to most of it down through the shifter boot, worse case is you may have to remove the floor boards and tunnel cover.
Center Diff Lock Issues (on, off, or in-between) Heath Defender Technical Discussions 10 October 29th, 2017 01:39 AM
Diff Lock Light Wiring for 83-89 -- Modern T Case Switch Answered SafariHP Defender Technical Discussions 0 September 3rd, 2009 12:36 PM
Diff Lock Remains Engaged but Light is Off - Whats Wrong? R. Kurk Defender Technical Discussions 14 April 5th, 2009 12:01 AM
Diff Lock Andrew Vick Defender Technical Discussions 3 August 26th, 2007 10:05 AM
4 Wheel / Diff Lock hamiamham Defender Technical Discussions 4 August 7th, 2007 08:50 PM
» Defender Registry
My Baby
Seiders
Lola
Nooner
Add your Defender
