Diff Lock Light Wiring for 83-89 -- Modern T Case Switch Answered - Defender Source
Old September 3rd, 2009, 12:36 PM
SafariHP's Avatar
SafariHP
Safari Heritage Parts
1983 Defender 110
To wire a newer style Diff Lock Warning Switch to an older truck
The 83-86 Defender
Black w blue trace goes back into the instrument cluster.
New Switch
Green w yellow trace
Green with brown trace
Connect the green w brown trace to the existing Blue w black trace wire. This will lead back into the cluster.
Add a ring terminal to the green w yellow trace wire and ground to any screw on the transfer case.
Your diff lock light should now work.
a year from now when I need this now I know where to look for it.
ht, mod, switch, wiring
Center Diff Lock Issues (on, off, or in-between) Heath Defender Technical Discussions 10 October 29th, 2017 01:39 AM
Diff Lock Light Wiring SafariHP Defender Technical Discussions 7 September 2nd, 2009 06:01 PM
Diff Lock Remains Engaged but Light is Off - Whats Wrong? R. Kurk Defender Technical Discussions 14 April 5th, 2009 12:01 AM
Main light switch jchan88 Defender Technical Discussions 3 November 13th, 2005 09:43 PM
