Diff-Lock Light Reverse Logic???? - Defender Source
Old October 11th, 2006, 12:53 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Hi,
I recently replaced a few seal on my T-Case ('95 D90). As I did that I got the
opportunity to try to fix/replace the screw/sensor that make the diff
lock light up when the diff lock is engaged.
I "kinda" had to screw it quickly to go to MAR on Friday night and I
might have not done it properly (read "I did not re-read the setup
steps from the workshop manual").
Now the behavior is:
- the diff lock light turns on when the diff lock is supposed to be
disengaged.
- the diff lock light turns off when the diff lock is supposed to be engaged.
=> exactly the opposite from what I expected
So.... Did anyone run into a similar issue? I don't think there is a
way to mess up the way the T-Case is installed, but.... maybe I don't
remember it correctly. I would like to avoid removing all that trim if
I don't have to! :-)
MonLand
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 11th, 2006, 12:09 PM
MonLand
Loic Fabro
Just as additional information: the bolt/switch is just an on/off switch and can not be wired incorrectly. I would still love to hear that this is due to a simple mistake that can easily be corrected....
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 11th, 2006, 01:21 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
I don't think you can incorrectly install the switch. It is a normally open switch that closes when the plunger is depressed by the diff lock mechanism, providing a ground path and turning on the light. Maybe you got the wrong switch and it is a normally closed type. What part number did you use?
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old October 11th, 2006, 02:14 PM
MonLand
Loic Fabro
Hum..... Not sure what part number I used, I used the one Atlantic British sent me without really checking.
It's probably (AB Part Number?) PRC2911. The only one I can see on their web site (http://www.roverparts.com/Parts/PRC2911.cfm).
The strange thing is that it is open by default (and I am pretty sure the one I removed was also normally open).
Now.... If I can't install the switch incorrectly.... What did I mess up! :-(
I'll have to try to lift a tire and see if the diff actually locks. I hope it still does.... Pulling the T-case wasn't exactly the easiest.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old December 5th, 2006, 12:33 AM
nosivad_bor's Avatar
nosivad_bor
Rob Davison
1999 Disco1
any resolution to this problem?
-rob
Old December 5th, 2006, 12:31 PM
MonLand
Loic Fabro
Nope, the light is still on..... I just need to take the time.... :-(
My last guess is that I screwed the bolt too far. What I did discover though, is that eventhough the light is on (or off), the diff does not lock. So I think the screw is too far and prevents the locking mechanism (spring loaded) to actually actuate the locker.
MonLand
1995 D90 NAS
1996 Discovery NAS
ht
Center Diff Lock Issues (on, off, or in-between) Heath Defender Technical Discussions 10 October 29th, 2017 01:39 AM
Diff Lock Light Wiring for 83-89 -- Modern T Case Switch Answered SafariHP Defender Technical Discussions 0 September 3rd, 2009 12:36 PM
Diff Lock Remains Engaged but Light is Off - Whats Wrong? R. Kurk Defender Technical Discussions 14 April 5th, 2009 12:01 AM
Help, no reverse light Glenn_Guinto Defender Technical Discussions 7 December 26th, 2003 04:17 PM
Reverse Light is Slow to Turn On-Why? JRowe Defender Technical Discussions 1 December 12th, 2003 05:03 PM
