diff Lock Light Illuminated but not locked - Defender Source
Old June 27th, 2016, 03:03 PM
joyride8
Logan Feldman
1997 D90
i was on the trails this weekend and initially after engaging the diff lock, the light came on but i felt the vehicle slipping and had tire spin which led me to realize even tho the light was on , the differentials were not locked. it took a few attempt to disengage and reengage the diff lock before they finally locked (on flat ground, rolled etc etc) any ideas of what is worth checking out to get to the root of the issue of the light coming on before they actually lock? the car does sit a good amount of the year with a few miles put on every month. a friend suggested i need to get it into low range now and then as well as lock the diffs which i understand will help in the future but looking to solve this issue ... thanks
Old June 27th, 2016, 03:09 PM
Look up in the manual on the adjustment of the diff lock linkage. It is pretty clearly explained there.
Old June 27th, 2016, 03:15 PM
joyride8
Logan Feldman
1997 D90
You said differentials. Diff lock only locks the center diff in the Tcase. The axle diffs are still open so you can get crossaxled and still spin a front and rear tire.
-Jeff
def correct, i meant center diff
Old June 27th, 2016, 04:28 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
The lamp is on duty when the fork is moved in place by the spring.
So it might be possible the the fork has broken off the cam?
ht
Land Rover illuminated dealer sign toddw Wanted 13 March 9th, 2014 10:34 PM
Center Diff Locked will not Unlock! Hammertime Defender Technical Discussions 2 May 7th, 2009 03:16 AM
Diff Lock Remains Engaged but Light is Off - Whats Wrong? R. Kurk Defender Technical Discussions 14 April 5th, 2009 12:01 AM
Illuminated rocker switch source pmd Misc. Chit-Chat 7 March 9th, 2007 06:20 PM
