diff lock light - Defender Source
Old August 7th, 2008, 10:56 PM
phunter
phunter
1993 NAS 110
diff lock light
diff lock light will not come on. any ideas how to check the transfer case or mechanism. is there a fuse i am missing
any help is appreciated
Old August 7th, 2008, 11:07 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Is it not locking and just not indicating? Has it indicated before? Could it just be a blown bulb? Two screws to take your binacle out and check the bulb by replacing it with a known good bulb.This would be my first trouble shooting effort.
Old August 7th, 2008, 11:31 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Check your fuses before doing anything.
Before taking anything apart, I would test the diff lock.
Put the truck on 4 jack stands (or two one up front one in the rear, see later why), move the diff lock to "locked" turn the front and rear driveshaft with your hands in opposite directions to try to lock the differential (it probably will be easier to block one wheel and turn the other one.
At some point, the differential should lock. When locked, you will see that your front and rear driveshaft turn in the same direction at the same speed (i.e. wheels turn in the same direction/same speed).
It is does not lock, then this is a mechanical (or linkage) issue. It is does, then this is an electrical issue (fuse, wiring, switch or bulb).
I'm sure a nicer way of testing the diff lock exists somewhere here.
On mine, it was the switch that broke. Could be fixed (and was fixed) but I ordered a (expensive IIRC) replacement. I have yet to get the adjustment right....
MonLand
1995 D90 NAS
1996 Discovery NAS
ht
Center Diff Lock Issues (on, off, or in-between) Heath Defender Technical Discussions 10 October 29th, 2017 01:39 AM
center diff lock light bjf Defender Technical Discussions 16 June 25th, 2016 07:06 PM
Diff Lock Light Wiring for 83-89 -- Modern T Case Switch Answered SafariHP Defender Technical Discussions 0 September 3rd, 2009 12:36 PM
Diff Lock Light Wiring SafariHP Defender Technical Discussions 7 September 2nd, 2009 06:01 PM
Diff Lock Remains Engaged but Light is Off - Whats Wrong? R. Kurk Defender Technical Discussions 14 April 5th, 2009 12:01 AM
