Diff gear contact pattern pictures - Page 2 - Defender Source
Old September 13th, 2015, 10:50 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Originally Posted by cgalpin View Post
Here is the end state of my rear diff. Unless someone yells nooooooooo, I'm done.
Nooooooooo! Why did you pick yellow as the color to paint your gears???? Everyone knows drivetrain components are supposed to be painted red! Back to the sanding cabinet Charles and clean up those parts. Might be a good time to get them galvanized like every part of your truck anyway!
MonLand
1995 D90 NAS
1996 Discovery NAS
Old September 20th, 2015, 08:56 PM
Just in case someone reads this and mistakenly thinks that FTC4939G is the correct seal for the pinion on a diff, it's not. And hopefully they don't destroy two of them before going inside and looking up the part number to see they just destroyed their LT230 output shaft seals and should have been using a FTC5258 instead. Even better if they avoid spending an hour getting setup to put the damn diff in their press and then pressing a FTC4939G in and noting that it still kinked like the first one
Well, I say I'm done, but for some reason I'm having a hell of a time installing the pinion seal on the rear. I've destroyed a seal already so I'll take a break and try again tomorrow. Had no issues on the front, same cortico FTC4939G seal
Originally Posted by pendy
I'm here for the D's
Old September 21st, 2015, 06:39 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Charles, I might have a spare if you need it quickly. I'll need to double check the pt#.
Old September 21st, 2015, 07:51 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
No need to use a press to install the seal. Just get something close to the same diameter and tap tap tap it in.
Old September 21st, 2015, 07:58 PM
Clay, I'm good - I had the right ones of course I am in no rush, but just need to replace the ones I ruined.
Brett, right you are. In fact I can "press" them in with the palms of my hands...when using the right seal
Call me a dumbass - it's true!
Old September 21st, 2015, 08:03 PM
I asked for that, didn't I
ac
FS: Used Defender Mat w/ 5-bar checker plate pattern Chaucer For Sale - Parts 2 March 11th, 2008 10:57 AM
Wheel Bolt Pattern NashvilleRover Defender Technical Discussions 3 October 12th, 2007 11:07 PM
LR3 bolt pattern and wheel studs trailerman Defender Technical Discussions 0 May 27th, 2006 10:32 AM
New tread pattern for BFG MT sheki Misc. Chit-Chat 15 September 16th, 2005 09:16 AM
Bolt Pattern Joe P Defender Technical Discussions 3 December 29th, 2004 11:06 PM
