diff fluid level - Defender Source
Old December 28th, 2013, 09:54 PM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
diff fluid level
So I crack open the TOP (filler) bolt on my front diff. Glug glug, about 6 oz or more of gear oil come pouring out of the filler hole (not the bottom drain hole, which is still plugged). Now, I believe my D90 which I bought 6 months ago has a slight lift, maybe 1.5" or 2" by PO. Is it possible lifting the vehicle can change the driveline angle so that the diff pumpkin filler hole is now at an different angle? If so, do I still go by "fill until the filler hole leaks" method?
Old December 28th, 2013, 09:55 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Originally Posted by CaptMidnite View Post
So I crack open the TOP (filler) bolt on my front diff. Glug glug, about 10 oz or more of gear oil come pouring out of the filler hole (not the bottom drain hole, which is still plugged). Now, I believe my D90 which I bought 6 months ago has a slight lift, maybe 1.5" or 2" by PO. Is it possible lifting the vehicle can change the driveline angle so that the diff pumpkin filler hole is now at an different angle? If so, do I still go by "fill until the filler hole leaks" method?
Did you drain the rest of it from the bottom? I think oil floats on top of water...
You little rebel, I like you.
Old December 28th, 2013, 09:56 PM
87 D110 (Ruby)
nope - filling with oil from the swivel balls - your seals are bad...fun job
Old December 28th, 2013, 09:57 PM
CaptMidnite
Daniel Choi
Yes, oil doesn't look water contaminated. (will check again though, what does water contaminated oil look like? grayish?). Didn't consider that possibility.
87 D110 (Ruby)
it stinks...bad
Old December 28th, 2013, 09:58 PM
CaptMidnite
Daniel Choi
ouch.. swivel ball. Ok, according to a sticker on the radiator the passenger side has "one-shot." So the driver side must still be oiled up. The driver side swivel ball looks dry from the outside, so internal leak?
Old December 28th, 2013, 10:03 PM
take a lesson from a lady for a swivel ball seal hack ..
http://www.expeditionlandrover.info/LRhubseal.htm
Old December 28th, 2013, 10:06 PM
CaptMidnite
Daniel Choi
While I'm at it, maybe I should clean out the "one-shot" from the passenger side and replace with proper gear oil? From other threads, I think the consensus leans toward the original spec oil instead of grease.
------ Follow up post added December 28th, 2013 10:10 PM ------
it stinks...bad
Hmm, but I think gear oil in general has a funky smell because of its sulphur content?
Old December 28th, 2013, 10:30 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Sometimes it'll look like chocolate milk!
I used to be a gear-oil-only in the swivels but in the last few years I appreciate the truck with one-shot grease....doesn't drip!
Rent my
Old December 28th, 2013, 10:41 PM
87 D110 (Ruby)
grease...factory recommended - must be right
Old December 28th, 2013, 10:57 PM
CaptMidnite
Daniel Choi
The alleged motive behind LR switching to grease is that yuppie owners complained about "oil leaks" on their driveways.
One advantage of gear oil is it is easily changeable after a day of heavy mudding, and also you can tell if the seal is leaking.
Old December 28th, 2013, 11:47 PM
It's not THAT bad...you can pull the entire assembly with the 6 bolts at the axle flange and pull the whole thing off...seals are right there.
I also don't think it's that big of a deal if the swivels are leaking into the axle tube - just pop the fill plug on the diff when you fill the swivels. Swivel balls only call for like .33 Qt to fill anyhow, which will get you to about the bottom of the axle tube.
Old December 29th, 2013, 09:24 AM
I was apprehensive about cutting the swivel seal but it seems to work as posted above.
Old December 29th, 2013, 09:39 AM
I agree with NOT cutting the seal (I think you're referencing how some folks cut the outside/exterior swivel ball seal #FCT3401 to fit a new one in place on the outside of the swivel ball itself)....mainly because if you just pull the 6 bolts on the housing itself where it bolts to the axle tube you can slip a new seal right over and does not take that long to do it correctly.
But that aside, his issue I think is actually the INNER Oil Seal on the Swivel Ball Housing #FTC3276 (it's the smallish seal that the axle itself slides in to and keeps the fluid in the swivel ball housing versus flowing over into the axle tube).
Old December 29th, 2013, 10:04 AM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
One shot and gear oil both, still lets you drain the soupy mess nd seems to hold off leaks.
Old December 29th, 2013, 02:41 PM
CaptMidnite
Daniel Choi
Thanks everyone for your tips. Leaning towards disassembly of both swivel balls to inspect, regrease and check seals. Found a detailed, well illustrated write-up:
http://www.repairmylandrover.co.uk/d...ll-replacement
Old December 29th, 2013, 02:56 PM
Wait...so are your swivels leaking outside (at the external swivel seal - #6 on the diagram) or is it just overfilling the diff? If it's just the diff overfilling there's no need to pull it all completely apart, just pull the entire assembly by unbolting it from the axle tube and replace #12 shown in the diagram.
Chances are the #12 seal just got "popped" out at some point by someone taking axles in and out.
Old December 29th, 2013, 03:22 PM
CaptMidnite
Daniel Choi
Hmm, outside /inner wheel rim area looks dry. Will check inner seals first. I know passenger side has had one-shot put in by a LR dealer about a year ago.
Old December 29th, 2013, 04:33 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Capt, back to your first post...I guess theoretically it's possible if your truck has been lifted, the axle/diff is now pointed more downward= *more* oil.
If you're not leaking oil out of the hub end...I'm not sure I would tear into the swivels....
Just make sure you've got oil/grease in both swivels and the diff !?!
Rent my
Old December 29th, 2013, 05:33 PM
CaptMidnite
Daniel Choi
Revisiting that idea, I wonder if that is possible. Probably the driveshaft just angles higher while the diff stays level. I can imagine for maybe an extreme custom lift, but not for a mild lift.
Center Diff Lock Issues (on, off, or in-between) Heath Defender Technical Discussions 10 October 29th, 2017 01:39 AM
Coolant fluid level sensor leastonce Defender Technical Discussions 1 October 5th, 2010 08:59 PM
diff fluid color JBOD77 Defender Technical Discussions 1 March 31st, 2009 09:08 PM
ZF fluid level goes up and down 48vphantom Defender Technical Discussions 4 March 20th, 2005 01:42 PM
