diff fluid level - Page 2 - Defender Source
Old December 29th, 2013, 06:27 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Lifting it would angle the fill further down, and would give slightly less. But parking on a slope or on ramps or jack stands would allow you to over fill slightly.
-Jeff
I usually go for the slight overfill by putting one side on wheel ramps. Might cause leaks if a seal fails.
You can always put some EP90 in with the one shot makes it drain out when you need it to. I don't see much problem with an internal leak between the swivel and main axle unless it's all one way and the swivel ends up running dry. No doubt someone will chime in and tell me how wrong that is and I'll feel the need to rush out and check the seals on the 110.
Mike Hammond
Center Diff Lock Issues (on, off, or in-between) Heath Defender Technical Discussions 10 October 29th, 2017 01:39 AM
Coolant fluid level sensor leastonce Defender Technical Discussions 1 October 5th, 2010 08:59 PM
diff fluid color JBOD77 Defender Technical Discussions 1 March 31st, 2009 09:08 PM
ZF fluid level goes up and down 48vphantom Defender Technical Discussions 4 March 20th, 2005 01:42 PM
