diff fluid color - Defender Source
Old March 31st, 2009, 08:32 PM
JBOD77
Jonathan
1995 D90 ST Beluga Black
Exclamation diff fluid color
changed out front and rear diff fluid today. both diffs poured fluid out of the fill caps.?.?.? I'm assuming that they're overfilled? Question is the color of the fluid. The snot that was in the truck was a grayish greenish color. Is that indicative if water contamination? If not why the severe color difference. Also, would overfilling the diffs cause any problems? when I filled them back up I only put the normal amount. (I stooped when it started coming out the fill hole.
This is where I'm supposed to write something witty and funny; or something.
Old March 31st, 2009, 09:08 PM
Normal on all accounts. Overfilling will not cause any issues. Check to make sure your swivel balls are full as sometimes the fluid makes its way from them into the axle housing in front.
Center Diff Lock Issues (on, off, or in-between) Heath Defender Technical Discussions 10 October 29th, 2017 01:39 AM
The meaning behind your Defender color! ini88 Misc. Chit-Chat 5 March 7th, 2007 01:41 PM
ZF fluid level goes up and down 48vphantom Defender Technical Discussions 4 March 20th, 2005 01:42 PM
need front/rear diff for 1994 D90 rover_rich_d90 Wanted 4 March 14th, 2005 09:05 PM
