Diff Flange Removal HELP! - Defender Source
Old August 26th, 2006, 11:23 AM
ronward's Avatar
ronward
Redsrover
None - sadly
Hi all, removing the rear Salisbury pinion seal and having trouble getting the diff flange off. The nut and washer are off with the impact gun. The pinion flange seems to slip right onto the pinion splines, but won't budge off of it. Any ideas for getting this thing off?
Anything is possible, with the right tools...
Old August 26th, 2006, 11:52 AM
redrover
Guest
Posts: n/a
I just use a simple two jaw gear puller when they are stuck. Cheap at any auto part store. JP leland tfryyyyyuyhhhhujmkm,lkiuy7hujuy765tgyhgytggtbhgbbg gbhhgyghbgyhgtryy.
Old August 26th, 2006, 04:22 PM
ronward's Avatar
ronward
Redsrover
None - sadly
Yup, bought a 2 or 3 jaw puller at Sears while I was out for lunch. Easy-peasy after that. Interesting orientation to seal replacement when the replacement part is modern and the seal being replaced is some 22 years old. Boy those pinion seals are a tight fit! Torqued pinion nut back down to 125lbs and test drove it on the highway. No drips, no leaks, nice.
Tomorrow... the oil change.
Oh and how about my hometown Northern little league team beating the tar out of N.H. Thursday night and putting a whoopin on Beaverton Oregon right now? Nice!
Center Diff Lock Issues (on, off, or in-between) Heath Defender Technical Discussions 10 October 29th, 2017 01:39 AM
Muffler Flange Bolt removal Bozman Defender Technical Discussions 2 May 28th, 2009 06:43 PM
QT Services Diff Guards and HD Engine Mounts JohnC The Vendors Loft 1 February 16th, 2006 09:53 PM
need front/rear diff for 1994 D90 rover_rich_d90 Wanted 4 March 14th, 2005 09:05 PM
