diff breather tube size? - Defender Source
Old November 23rd, 2009, 02:26 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Need to repair/extend the breather tubes -- can anyone advise on the ID of the tube and, even better, a source for some that lasts longer than the rover crap?
Old November 23rd, 2009, 03:03 PM
I cant offer much other than some folks I know have made some really nice breathers up to the firewall using a little manifold and larger tubing.
Old November 23rd, 2009, 03:24 PM
I used a piece from my old RR's EAS system. How much do you need, I may still have some?
Old November 23rd, 2009, 03:51 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Likely a lot -- I need to repair the rear (ripped off all but the last few inches at MAR) and I'd might as well run all of them up the snorkel while I'm at it.
Old November 23rd, 2009, 06:07 PM
Tony I have bad news for you. By the time you are in water up above the firewall your engine will have long since quit and your ECU will be fried. At that point water finds its way into the axles in other ways.
The hard plastic hose I've had is about 1/8" I.D. and I have found it available at my FLAPS with other "by the foot" hoses. You might have to go to a few places before you find it.
Boiling water to soften it and shove it over whatever end you are trying to fit to it. Thanks to JP for that tip it works much better than the heat gun I was using before.
Make sure it is well fastened to the axle or you'll lose it again. Just got finished booger-welding my new diff cover on my front axle to replace the one I lost @ MAR. PITA job that...
Gee, I sure use alot of acronyms. LOL.
Roll cage tube size ... Retrofit Defender Technical Discussions 4 August 12th, 2008 05:18 PM
Thread size on rear axle for diff cover install? pmd Defender Technical Discussions 4 March 16th, 2008 10:53 AM
New style breather tube!! 48vphantom Defender Technical Discussions 1 August 7th, 2005 09:05 PM
Bolt size for Diff? UpnOver Defender Technical Discussions 3 July 5th, 2005 08:28 AM
need front/rear diff for 1994 D90 rover_rich_d90 Wanted 4 March 14th, 2005 09:05 PM
