Diff and tcase plugs are stuck - Defender Source
Old March 19th, 2011, 09:45 AM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Won't budge - ok to use penetrating oil or some other technique? PO didn't seem to pay a ton of attention but it's time to replace the oil..
-Ren Ching
Old March 19th, 2011, 10:42 AM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
Yeah I don't see a problem using some pb blaster or kroil on it.... the miniscule amount that may make it through the threads into the oil wouldnt cause a problem, and anyways, you're planning on dumping it all anyways.
You can replace the plugs too to make it easier in the future;
http://www.expeditionexchange.com/brassplug/
or
http://www.lucky8llc.com/Products.aspx?ProductID=2778
(you can also find something that'll work at a hardware/plumbing store, I just don't remember the size)
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old March 19th, 2011, 11:03 AM
Never knew/realized they were the same as the radiator plug. Cool.
Old March 19th, 2011, 11:09 AM
smob's Avatar
smob
Steve
Me neither. Good advice. Thanks.
-Ren Ching
Old March 19th, 2011, 11:23 AM
rmuller
Ryan
At least on the Discovery 2's they are... they may be different on the D90/D1 ... I never tried them on my 90 when I had it.
Ryan
Current:
2001 Discovery II
2006 LR3 HSE7
that's because they aren't.
Steve, try some heat and a breaker bar.
Penetrating oil without heat is about as useful as a football bat.
Don't worry about changing the plugs unless there is something wrong with them. They were probably just overtightened.
The brass radiator plugs from EE are seriously overpriced, RDS has them for $5.
Old March 19th, 2011, 03:46 PM
smob's Avatar
smob
Steve
Aw yeah, breaker bar worked by itself on the diffs. I'll do the same thing for the tcase, but maybe a little more gently. It looks like they were overtightened and spraypainted several times over.. Thanks DB.
-Ren Ching
Old March 19th, 2011, 04:22 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
x2, thats how I got my plug off too. soaked in liq wrench for an hour or 2, propane torch directly on the plug for 10 seconds or so. breaker bar, popped right off.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Diff Lock Andrew Vick Defender Technical Discussions 3 August 26th, 2007 10:05 AM
Tcase Noise in low with CDL locked Baldewin Defender Technical Discussions 1 July 9th, 2007 10:41 AM
