Diff and T/C grear oil - frequency - Defender Source
Old November 2nd, 2015, 12:26 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Use Redline 75w-90 like many here. Changed the front diff at 7.5k and rear (w/ truetrac) at 5k. Oil looked fine but used. About to change the t/c oil at 7.5k but it still looked new. Like zero miles new. Is that normal?
Old November 2nd, 2015, 01:12 AM
DailyDrivenDefende
Michael
1989 110, 1985 90 200TDI
Gear oil should come out clean unless there has been water contamination between intervals. Engine oil on the other hand is exposed tougher operating condition with direct exposure to ignition, pressure, heat.... why look so much dirtier.
Old November 2nd, 2015, 01:31 AM
Factory service interval is 30k with regular Dino. If you don't get water in it, synthetic gear oil will last pretty much indefinitely. 30k service is more than sufficient but check it every oil change and top up as needed.
Old November 2nd, 2015, 06:57 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
I just changed my diff oil this weekend and they were both had water contamination. I do not know how old the old was. What's the main source for water ingress into the diffs?
Old November 2nd, 2015, 08:50 AM
Grover's Avatar
Grover
Question
Why change at 7.5k?
Spiral bevel gears in the diffs may wear differently than helical gears in the TC.
Old November 2nd, 2015, 08:57 AM
Yes, 30k is way more than enough. If you are wading, then you should be checking it after a run to make sure it is not contaminated.
Old November 2nd, 2015, 09:22 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
That's why I buy the Dino stuff in a 5 gallon pail and use a lever pump. Synthetic isn't worth the investment if your truck sees water.
Old November 2nd, 2015, 09:31 AM
DailyDrivenDefende
Michael
Is your breather tube connected right? If any of the seals that keeps oil in the axle is leaking, you can assume water can get in.
This is part of the reason why I'd rather change out cheap oil often than keep expensive oil for long.
Old November 2nd, 2015, 09:40 AM
down_shift's Avatar
down_shift
Russell
Originally Posted by Grover View Post
Why change at 7.5k?
Needed to change the engine oil & filter (3k, looked great, no particulates, lightweight filter). Given the coveralls were on, 3-yr old is napping, admiral's green light received, best to take advantage of this diminishing opportunity. Justin mentioned changing the diff oil after a few thousand on the new truetrac install. Then once the suction pump is out and filled with gear oil..... you get the idea.
I'll check the diff breather lines for a leak. Perhaps the truetrac had some moly grease in there.
Old November 2nd, 2015, 10:30 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
My diff fluids have never come our looking new (golden). Always gray and smelly, even once when I swapped out a diff after a couple months during a trouble shooting wild goose chase.
Old November 2nd, 2015, 11:55 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Old, leaky seals... then wading when the axle is hot will suck water into the axle.
Rent my
Old November 2nd, 2015, 12:14 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
Old, leaky seals... then wading when the axle is hot will suck water into the axle. .
I've read somewhere that people have used an air compressor to pressurize the diffs to alleviate that. I'd like to do that.
Black Rhino Lives Matter
Old November 2nd, 2015, 12:44 PM
If you oil gets contaminated off road.....you should then fix the leaking seals.....and make sure the breather is clear and has been located to a safe and high location. you really do not want to toast all of your bearings while in the bush.
I do agree, there is no justification for using synthetic in the axles. I've never seen any of these axle components wear unless the oil got contaminated. Regular gear oil will protect them forever. Synthetic will just be foreverer.
Only if the breather is not clear.
Old November 2nd, 2015, 12:52 PM
Grover's Avatar
Grover
Smile
Yup, with a toddler of my own, I know where you are coming from...
I'm about to change the diffs and TC with RL75w90...
Cheers...
Old November 2nd, 2015, 01:48 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Yes.
Make sure the axle vent/breather is clear.
I've got an article(somewhere) about some of the RRC's in Australia that run slightly pressurized air in the axles to keep air out.
Seems like a lot more work...
Rent my
Old November 2nd, 2015, 04:42 PM
Grover's Avatar
Grover
Yes.
I would just avoid the puddles...
Old November 2nd, 2015, 09:14 PM
DailyDrivenDefende
Michael
Just make sure seals are good and have the breather tube located high up. Whole point of the breather tube is so that pressure is equalized in the axle to the atmosphere with change in temperature so you don't blow the seals.
Forget this pressurizing the diff case... That sounds like a surest way to blow seals and cause leak. Leak can go both ways, in and out.
Old November 2nd, 2015, 09:56 PM
It is not a day off road unless you have water over the hood.
Defender 200tdi...oil pressure sensor and diff lock switch sonoronos Defender Technical Discussions 4 July 28th, 2011 05:10 PM
Salisbury Diff Cover Bolts - ARB Diff Cover Shearpin Smaller Projects 4 February 20th, 2008 03:52 PM
93 NAS D-110 Diff oil and Hub Seal Questions AHollander Defender Technical Discussions 16 October 23rd, 2007 02:46 AM
110 rear diff protection (Salisbury diff guards) dave_lucas The Vendors Loft 13 October 25th, 2005 09:08 AM
OIL...oil...oil... norros Defender Technical Discussions 20 August 22nd, 2004 01:30 AM
