Dif-Lock operation.... - Page 2 - Defender Source
Old July 26th, 2005, 10:25 AM
DaveHuny's Avatar
DaveHuny
Van Der Waal
none
Well, my truck was originally a TX truck. Maybe the Texans needed a different manual
Old July 26th, 2005, 01:10 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Yeah, when you start the hill climb in a TX truck, just pick up the cadence! Vive Lance.
Old July 31st, 2005, 04:04 AM
BarryO
Barry O'Mahony
97 D-90 SW LE
Originally Posted by Doug
I've driven Chammy at 80 mph on hard salt flats in NV, locked up. Never an issue. Also drifted her through dozens of graded turns, on hard sand to loose gravel in the deep badlands, locked.
Yea, lot's of loose gravel and other unpaved surfaces around here; I drive with diffs locked at speeds way over 20 mph. Makes drifting through those loose gravel turns @ 45 MPH alot more controllable.
The main thing to keep in mind with the diff lock it that in a turn, the rear wheels travel in smaller-radius paths than do the fronts. So an open diff is needed between the front and rear axles on hard pavement, to allow the rear axle to spin slower than the front. On loose surfaces, you're better off with the axles locked at the same speed.
Center Diff Lock Issues (on, off, or in-between) Heath Defender Technical Discussions 10 October 29th, 2017 01:39 AM
Door Locks Don't Lock ronward Defender Technical Discussions 3 August 27th, 2005 04:57 PM
RRC non-ABS: can you lock brakes? artm Defender Technical Discussions 1 May 30th, 2005 07:13 PM
diif lock inquiry rover4x4 Defender Technical Discussions 16 February 6th, 2004 07:35 PM
lock the tailgate?? Campbell Defender Technical Discussions 9 December 8th, 2003 05:46 PM
