Diesels, if given a choice - Defender Source
Old November 7th, 2012, 09:22 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Say all else being equal, is the consensus to go with a Td5 over a 300 Tdi, or is there a legitimate concern with the Td5's electronics?
Old November 7th, 2012, 09:48 AM
300tdi convert
Michael Giddinge
Late 80s 110 300tdi
The TD5 was designed to address increasingly stringent EU emissions requirements. However, in parts of the world, the 300TDi continued in production and basically skipped the TD5. Israeli military continued using the 300TDi for maintenance reasons well into the 2000s. If there is a better engine to go with, it would be the South American 2.8 ltr diesel (I believe a ford variation of the 300TDi, with a lot more torque and a VNT). I had heard that they were out of production but that may be wrong as I understand that East Coast Rover is still installing new conversions. Used 300TDIs are still readily available from the UK.
Old November 7th, 2012, 10:05 AM
A chipped and remapped Td5.
Old November 7th, 2012, 10:39 AM
The TD5 has an ECU to control it. They are pretty reliable and well understood but would make for a much more complex retrofit.
The power and performance of a 300Tdi is similar to a TD5 and has the advantage that it can be run from a single hot wire from the battery in an emergency.
The military and others continued to use the Tdi for the field servicability concerns ..
Old November 7th, 2012, 10:51 AM
Michael
Michael
Discovery 1998
300tdi or HS2.8l all the way!!! Drive by only 1 wire!!!
bjf's Avatar
bjf
barry f
94 ST #395
If given the choice I would want the td5. The td5 is much more drivable.
Old November 7th, 2012, 10:53 AM
Oh we're talking retro-fitting this puppy in the 90? Then 300 for the simplicity.
The Td5 can be a rocket ship, but the 300 is a simple beast. I'd want the Td5 for most of what I use the truck for, so it probably depends on what your intent is. If you're talking about something that can wade trough deep water, etc then I'd be inclined to choose the 300.
Old November 7th, 2012, 10:59 AM
Correct me if I am wrong, but I believe the TD5 requires a specific transmission/bellhousing.
Michael
Michael
Discovery 1998
Actually, i hear the fuel cut off solenoid can be replaced with full mechanical so no wire needed. I want to find one of these!!!
Old November 7th, 2012, 11:01 AM
down_shift's Avatar
down_shift
Russell
No retrofit and no interest in 4' deep water crossings. The Td5 is already installed on a D-110 that has been stateside for a few years. Also assuming the Td5 is better for hauling a car trailer?
Old November 7th, 2012, 11:04 AM
Naplm00
Matthew
The TD5 will have better road manners than the 300 and will also tow better than a stock 300.
that being said I would still go woth the 300 in terms of simplicity.
im running a 200
Old November 7th, 2012, 11:05 AM
yeah then it's totally fine ...
Old November 7th, 2012, 11:19 AM
cabell's Avatar
cabell
Cabell Crowther
Trails and short trips I'd vote for the 300 for its simplicity. As a daily driver or for longer trips the td5 is mighty nice. You can listen to your music, talk on your phone and go up hills without downshifting
Old November 7th, 2012, 06:27 PM
Grover's Avatar
Grover
Td5 uses a timing chain where as the 200/300 Tdi uses a timing belt.
Old November 7th, 2012, 06:38 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
TD5 can be plugged in and read at your local Land Rover dealer too.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old November 7th, 2012, 07:07 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
TDV6 w/ 6 speed manual...if all else is equal. http://portal.jeengineering.co.uk/de...nversions.html
You little rebel, I like you.
Old November 8th, 2012, 08:26 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I don't know about the HS2.8 pump, but on the 300 you can, in a pinch, remove the solenoid plunger and drive with no wire.
I'm more about simplicity so I'd choose the 300Tdi.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 8th, 2012, 08:56 AM
Chris Vitale's Avatar
Chris Vitale
'95 D90 ST 2.8L TDi #2050
I went through this exercies a few years back and decided on the 2.8.
The 2.8 It's build stronger than the 300 and comes with the highly sought after turbo. Yet just as simple to work on as the 300.
However, if you don't want to throw that kind of coin at it, and still looking for simplicity, the 300 is a mighty fine choice.
Old November 8th, 2012, 10:05 AM
The TDV6 is pretty awesome. 254bhp, 520 Nm of torque at 2000 rpm. 24mpg. More torque than a GM LS1 at just off the tick. *drool*
IMHO It would make a killer rock crawler engine when paired up with large radius tires.
Old November 8th, 2012, 10:20 AM
200 is the same deal. In my exerience the plunger typically sticks open so not closed so running isn't usually the issue, its shutting it down.
Russell you are welcome to come down and drive a td5 and a 300 and see what you think.
Cheers,
diesel
Cam choice kellymoe Defender Technical Discussions 11 February 20th, 2006 01:04 PM
color choice for wheels mpodgorski Defender Technical Discussions 25 April 21st, 2005 01:56 PM
Different kinds of diesels rustydefender Misc. Chit-Chat 22 February 10th, 2005 08:06 AM
Now HERE are some CHOICE Wheel Rims wicks Misc. Chit-Chat 6 May 20th, 2004 01:05 AM
Diesels R.B.Bailey Misc. Chit-Chat 53 November 28th, 2003 08:33 AM
