Diesels, if given a choice - Page 2 - Defender Source
Old November 8th, 2012, 10:22 AM
the fuel stop solenoid is a 300 tdi LR original part no on the 2.8, as are many, many other parts. I just replaced my 2.8 water pump with a 300 tdi version. The only difference as an example was the 2.8 impeller is plastic, not metal.
Mark Kellgren
KM4BOR
Old November 8th, 2012, 10:59 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Thanks for the great feedback. It is pointing me to a Td5 for my application. To conclude this hypothetical exorcise, say a D-110 with a 300 Tdi is selling for $25,000. What would the same truck be worth with a Td5? The same, +$1000, -$1000, etc. The premium a 300 Tdi can fetch over a 2.5NAD is well discussed, I just haven’t located a comparisons to the Td5.
Doug - thanks for the offer. I'd like to take you up during one of these trail clearing excercises in BFE VA (as Bill would say....).
Old November 8th, 2012, 11:07 AM
Russell I haven't seen a td5 110 offered for sale below 35k.
bjf's Avatar
bjf
barry f
94 ST #395
I think it really depends on the truck. All the normal factors, like condition, rust, mileage, etc. When I think of td5s I think about 2002 or newer when the doors became galv, and the dash was updated. Those items seem to make the price jump.
Old November 8th, 2012, 11:16 AM
down_shift's Avatar
down_shift
Russell
Okay - the baseline D-110 with 300 Tdi is worth $35,000. The exact same truck with a Td5 is worth ___________.
Old November 8th, 2012, 11:47 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Originally Posted by down_shift View Post
okay - the baseline d-110 with 300 tdi is worth $35,000. The exact same truck with a td5 is worth ___________.
$40k+ Assuming interior is the same. Possibly a touch more with newer dash.
Old November 8th, 2012, 01:01 PM
Michael
Michael
Discovery 1998
200 is the same deal. In my exerience the plunger typically sticks open so not closed so running isn't usually the issue, its shutting it down.
Russell you are welcome to come down and drive a td5 and a 300 and see what you think.
Cheers,
That makes sense, other wise if no juice, the solenoid couldnt be energized to shut down engine.
------ Follow up post added November 8th, 2012 01:03 PM ------
So i guess, by removing solenoid, the engine can run, then inserting soledoid shuts fuel supply off
Old November 9th, 2012, 07:03 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
How they fail and how they operate can be different. They operate by opening when current is applied.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 10th, 2012, 04:19 PM
02 door frames are still alum skins over steel. 08 and up are the good ones
Old November 10th, 2012, 04:47 PM
bjf's Avatar
bjf
barry f
94 ST #395
Is that true for the back door too? I thought when the back door got updated all of them did.
Old November 10th, 2012, 05:26 PM
nope- you are right on the back door frames.
Old November 11th, 2012, 10:37 AM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Im about to go all in and pull the trigger on a diesel, hopefully the 2.8 from M&D or DiscoTech. Now that some of you have been running them for a few years, Id appreciate some feedback on performance, maintenance, issues, conversion process, etc. Id like to keep my ZF ( an uptated ZF from Ashcroft). If someone has one around the Georgia/Alabama/North Florida area, id love to give one a look see. thanks.
Old November 11th, 2012, 10:58 AM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Sorry about jumping the thread; thought any input would be beneficial to the OP as well.
Old November 11th, 2012, 11:54 AM
the rover shop
shayne young
I will be installing the Isuzu engine.. The 4bd1t engine I believe it is.. Supposed to be the best of the best.. Horsepower similar to the v8..( supposedly you can use the same auto trans as a v8 if you want as the rpm and horsepower curve is so close it allows the v8 trans to shift correctly) everyone I have spoke to about it says its awesome... I believe there is also a bigger variant 4bd2t.?? Now but have not researched it yet.. It's a very common transplant in England where there is lottts more defenders and fuel is expensive..turbo response is said to be almost instant at any rev range.. And let's face it..Isuzu have been building Diesel engines for quite some time now..have you looked into the Mercedes diesel conversion..???
Old November 11th, 2012, 12:14 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Very common as in adaptors and such available or would it be one off? Im going to have to research this.
Old November 11th, 2012, 12:26 PM
grnrvrs's Avatar
grnrvrs
Paul
88
The 4bd1t is a great engine and IMO, the best factory fit diesel in a LR. However, I would not be comfortable with putting LR spec auto box behind a 4bd series engine, because the torque pulse would eat it. The 6bd1t is the big brother and is a Bruiser. I'd love to see one stuffed into a 110/130. While the factory fit bell housing et al. are available from AUS, they are spendy. I would suggest using an MSA-5G mated to an LT230 behind a 4bd1t. Check out the Isuzu section of AULRO and look for Grubs adapter.
1970 SIIA 88, Sold
Old November 11th, 2012, 12:50 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Thanks. Hows everyday driveability? Sounds like its a bit ruff on power delivery and noise, as funny as that comment is regarding Defenders...
Old November 11th, 2012, 01:04 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I have been wanting to suggest the Isuzu engine but didn't want to stir the pot since the OP was talking about 300 vs td5. But since it's out there now...
I have been considering swapping it as well. I have heard great things about it. Here is a link to some brief history. It seems that there is a bit of rover heritage with some of these being fitted into Australian trucks.
http://www.isuzudieselswapper.com/
I saw Robert Davis' Mercedes swap at URE. That also looked to be a nice option. He put a lot of engineering into it to make it all work out.
Old November 11th, 2012, 01:12 PM
grnrvrs's Avatar
grnrvrs
Paul
88
I love my 4bd1t, power is great. I have all the torque i want, where I want it. At idle it does rattle but smooths out well just over idle. My 110 originally had zero NVH control, compounded by numerous holes in the bulkhead, seat box, c pillars, load bed floor etc. that let in significant ambient noise. When i imported it back in 08 in Tacoma WA, i drove home across WA state. I averaged 28 mpg and cruised over Snoqualimie pass at an easy 75-80 mph. A major component of my rebuild has been the mitigation of unwanted noise. When you step-up from a passenger vehicle diesel (e.g. 200/300/td5) to a truck engine (e.g.Isuzu 4BD series or Cummins 4BT series or larger) you will encounter more power and often times NVH. However, much of the NVH can be mitigated.
1970 SIIA 88, Sold
Old November 11th, 2012, 02:03 PM
tommyd's Avatar
tommyd
Tom
LR3
Paul, that's amazing. I wish I could do that with my 300. I would choose the 4BD1T if I had to do it over again. Doug will hopefully chime in; he performed a really nice swap into a 2000 Discovery II:
Wish I'd bought that truck. Someone on expo now owns it.
The 4BD1T was originally used in "Perentie" Defender 110s (and 6x6s) by the Australian army, and I think offered as an option on civilian models for a few years. The perentie is a very cool, large monitor lizard endemic to the central arid regions of Australia.
diesel
Cam choice kellymoe Defender Technical Discussions 11 February 20th, 2006 01:04 PM
color choice for wheels mpodgorski Defender Technical Discussions 25 April 21st, 2005 01:56 PM
Different kinds of diesels rustydefender Misc. Chit-Chat 22 February 10th, 2005 08:06 AM
Now HERE are some CHOICE Wheel Rims wicks Misc. Chit-Chat 6 May 20th, 2004 01:05 AM
Diesels R.B.Bailey Misc. Chit-Chat 53 November 28th, 2003 08:33 AM
