diesel timing kit - Defender Source
Old April 27th, 2013, 11:41 AM
jafir's Avatar
jafir
Jafir Elkurd
diesel timing kit
Has anyone bought this, or know anything about it: http://landroverparts.roversnorth.co...RNT2029&type=0
Does it have everything needed (as far as "special" tools) to do a timing belt job on a 2.5NA?
Or are there other options, besides trying to order the individual tools from land rover?
Old April 27th, 2013, 12:13 PM
I have that kit. I have used it on 2's and 3's but not 2.5 atmoshperic. Presumably it would have everything for that as well.
Old April 27th, 2013, 12:45 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
I also have the kit for the Tdi... there are a lot of bits in there I have never used, so maybe it's for the older engines?
Old April 27th, 2013, 06:09 PM
moose's Avatar
moose
Brett
Ex-Mod Tdi 110 Hard Top
I have the same kit. I've used it on the 2.5NA and 300Tdi. It has the flywheel locking pin and pump timing pin for the NA, so you are good to go.
Brett
Ex-Mod 110 Tdi
Series 3 88 Diesel Soft Top
Old April 27th, 2013, 06:17 PM
You really don't have to have or use the tools, but its somewhat more reassuring if you can insert the timing pump peg before using the locking grub screw to hold the pump.
Old April 27th, 2013, 10:46 PM
jafir's Avatar
jafir
Jafir Elkurd
Awesome. Thanks for the info everyone.
Old April 30th, 2013, 08:10 AM
I will check the diameter of the pump peg. I am gonna guess it is a regular size like 8mm or something. Then you can just use the butt end of a properly sized drill.
The main challenge to me was getting the crank pulley bolt out. I didn't have anything to really hold the flywheel. I used a 1/4" socket extension stuck into the large notch on the flywheel thru the bottom hole. I don't think it bungled the threads on the drain hole and even if it did I can clean them up or just use a rubber plug. There's a thread on making a flywheel holder tool on here somewhere.
diesel, kit
More on diesel / manual conversions Delta95 Defender Technical Discussions 37 September 4th, 2008 11:31 AM
Ex-MOD 2.5 diesel 90 EndlessEarth4WD Misc. Chit-Chat 18 January 26th, 2006 01:34 PM
Can you fab a diesel exhaust like a V8 exhaust? solihul Defender Technical Discussions 8 September 7th, 2005 04:09 PM
Timing and Overheating mkerr2112 Defender Technical Discussions 10 July 6th, 2005 09:31 AM
shop going under, diesel engines artm Defender Technical Discussions 0 May 12th, 2005 04:36 PM
