diesel swap in petrol LHD with AC and PS - Defender Source
Old April 10th, 2010, 01:23 PM
kjva
Ken Jackson
1985 110 Wagon
I have a 1985 LHD 110 Wagon with a 2.25 petrol engine factory fitted with air conditioning and power steering, has anyone done a 200 / 300 TDI engine swap with the extra pulleys.
Old April 10th, 2010, 01:35 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
The 300tdi has a power steering pump and kits are available to strap on an a/c - bracket for the compressor is on the engine already. I suspect you won't be able to use your current a/c however.
Old April 10th, 2010, 07:55 PM
Why not? It should only be the compressor that needs to be swapped. If it were me, I would swap a 200Tdi and buy the brackets which may or may not be the same as a 2.5 Petrol (blocks are similar, but I confess I have never seen a 2.5 w/ factory AC. I assume it is like the NAS 110 system.
Old April 11th, 2010, 07:14 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
take a pic of the a/c compressor... I'm sure It can be mounted. There is a bracket that mounts a v-8 comp to a Tdi...
Legend in My Own Mind.
Old April 11th, 2010, 08:26 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Bear in mind that the 300 (And very late 200's) have the ribbed serpentine belt, and thus different pullies, whereas the 2.25/2.5/200Tdi use the V belt (and the 200 has 2 belts, one for PAS and other for the engine & ancilliaries)
Old April 21st, 2010, 02:39 PM
piper109
Steve
1999 Disco 1 SD w/300tdi
Where can I get a bracket that mounts a V-8 compressor to a Tdi engine?
Old April 21st, 2010, 02:55 PM
you have to make it
Old April 22nd, 2010, 08:04 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
M&D Engineering have them.. Not sure what 200 you have.. Serp belt or v-belt
ac, diesel, lhd
D110 AC Repair Lesandjes Defender Technical Discussions 4 June 5th, 2008 12:55 PM
1978 FJ40 - RESTORED TO NEW - AC & PS FOR SALE OR TRADE geneseemtn For Sale - Vehicles 15 June 2nd, 2008 11:05 AM
