diesel sedimentator cleaning - Defender Source
Old October 4th, 2010, 07:08 PM
isleofbones's Avatar
isleofbones
Mike Deery
1984 D-90
Red face diesel sedimentator cleaning
I am looking to drain contaminants from my sedimentator on my 200tdi. Any guidance would be appreciated... Specifically, do I open up the drain nut with the ignition off or does it need the pressure of the pump operating? I have the same question regarding the diesel fuel filter drain valve. Thanks in advance for the help.
Old October 4th, 2010, 08:54 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
sedimentator is where?
Old October 4th, 2010, 09:30 PM
Naplm00
Matthew
yea same question, where is the water trap?
Old October 4th, 2010, 09:53 PM
isleofbones
Mike Deery
1984 D-90
Sedimentator is on bulkhead near fuel filter, slightly lower.
Old October 5th, 2010, 05:43 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I dont think I have one, is that a big deal?
Old October 5th, 2010, 09:10 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Your filter sort of does both jobs anyway, no big deal. The sedimentator takes out the twigs and bugs and most of the water, the filter does the fine stuff.
Old October 5th, 2010, 09:26 AM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
On my truck it's mounted in the right rear wheel well.
Old October 5th, 2010, 10:25 AM
It should be on the right rear wheel well.
Read the workshop manual.................
Unscrew the bolt on the top... Take the bowl off... Clean it... Put back on.
Old October 5th, 2010, 10:30 AM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi Mike your sedimentor should be cleaned with the ign & engine off.
before you start make sure you have new O rings I think there are 3.
drain it then release the bolt on the top & take the bowl off(sedimentor splits in half around the middle seam) and clean it out, on my disco it was 1/2 full with goo.
be carefull when removing the bolt as i have known them to shear esp if they are 1/2 full of goo.!
it should self prime after starting if you havent done the fuel filter at the same time.
after it has been running for a few mins for it to blead out and refill the canister it would be a good time to do the fuel filter as if you have found the sedimenter has goo in it then the filter surely will
same thing goes for the filter but you will have to manually prime & blead the filter after replacing it
regards
Gren
------ Follow up post added October 5th, 2010 03:31 PM ------
beat me to the punch john..;-)
Old October 5th, 2010, 04:36 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
And i'd not bother unscrewing that plastic "bung" thing... it'll probably snap... just undo the bolt through the middle and dis-assemble the whole thing... you can clean it out better in pieces anyway.
Old October 5th, 2010, 06:49 PM
isleofbones
Mike Deery
1984 D-90
cleaning diesel sedimentator
Gren-
What do I have to do regarding manually priming after opening the drain valve on the fuel filter? When I replaced the fuel filter about a year ago, I simply replaced it... no priming. After sputtering for a few seconds, the truck ran like normal.
Old October 5th, 2010, 08:44 PM
Chaucer
Will
93 110 | 97 90
I usually fill it up the fuel filter with new clean diesel (like filling up the oil filter on the V8s) then screw it on tight and start up. I never notice any sputter there.
For the sedimentor, I put a bucket underneath and take it apart spilling diesel into the bucket. Then I clean everything and reinstall empty. THen start up; and after a little sputter it's back to normal.
Like Gren says, do one at a time, not at the same time. I usually start with the sedimentor, (remove, clean, reinstall, start up until primed). Then do the filter as above.
Old October 5th, 2010, 09:44 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
What year did they use sedimentor? My 1983 110 2.5TD doesn't have one.
Old October 5th, 2010, 09:58 PM
isleofbones
Mike Deery
1984 D-90
Hey Tom-
Obviously I don't know too much about the sedimentator, but, I've always heard it referenced on the TDI diesel motors. I see it in my workshop manual pictures/diagrams, but, I couldn't find any detail on how to clean. That's why I called out to you guys. Thanks for the help. If you want to see what mine looks like, I may be out to Sayville this weekend.
Old October 5th, 2010, 10:32 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
i just ordered two of these on lr direct. One to replace mine and the other to have it as a model so i can make one out of brass or aluminium .
- Charles Eames
Old October 5th, 2010, 11:22 PM
discotdi
Todd Miller
Land Rover
how about a picture to show this thing? someone snap a cell phone pic or something. like to know what to look for.
Old October 6th, 2010, 10:39 AM
It is just an M8 thread, IIRC.... A regular bolt works.
Old October 6th, 2010, 10:42 AM
Is it just me, or cannot people read the workshop manual??? They are freely available online with really nice, pretty pictures and descriptions of what to do.
Picture from manual attached...
ID:	31900   Click image for larger version
Old October 6th, 2010, 11:34 AM
discotdi
Todd Miller
Land Rover
firstly I don't have a workshop manual for this car yet. secondly I prefer real pictures to cartoon stick drawings. thirdly the picture in the WS manual does not show the location and it seems like there are possibly multiple locations for said filter based on what people have said in this thread.
I suppose I could search all around the truck until I see something that looks like the WS pic, but I thought if someone is cleaning it , they could snap a pic. It is then easy to locate based on surrounding features.
thanks for the WS pic though, now I know what to look for.
Old October 6th, 2010, 12:34 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
The ones i received are 5/16 " - 18 , i'll post a pic later today.
- Charles Eames
diesel
More on diesel / manual conversions Delta95 Defender Technical Discussions 37 September 4th, 2008 11:31 AM
Ex-MOD 2.5 diesel 90 EndlessEarth4WD Misc. Chit-Chat 18 January 26th, 2006 01:34 PM
Can you fab a diesel exhaust like a V8 exhaust? solihul Defender Technical Discussions 8 September 7th, 2005 04:09 PM
Izuzu diesel swap rustydefender Misc. Chit-Chat 10 August 1st, 2005 03:52 PM
shop going under, diesel engines artm Defender Technical Discussions 0 May 12th, 2005 04:36 PM
