Diesel options for '87 RRC - Defender Source
Old March 8th, 2010, 10:35 PM
Lucasd2002's Avatar
Lucasd2002
David Lucas
[VACANT]
I have a friend here in CT who has a 1987 RRC with the original 3.5L motor. I think he has owned it for 20 years and the motor is getting tired.
We have talked about putting a diesel in it. He wants to stay with an automatic. He is the type of guy that would want to do it himself, he has a nice garage with a lift, etc. I know 2 of his best options are 300TDI and PS2.8.
Beyond that, I am out of my comfort zone...
Pendy has told me that has parts available to "convert the transmission" (the ZF in the RRC) to work with a 300TDI. Is that needed for a PS2.8 also?
From reading the 2.8 thread, it sounded like David Shechter's truck had a ZF but it wasn't clear if it was converted. Then the '97 D90 version (ZF 4HP22) was rebuilt to P38 (ZF 4HP24) specs.
I know the MDE kits come with some things like motor mounts and adapter plates...
But I don't think my friends wants to spend MDE-type money.
I know some people have bought from Duncan from landroverimports even though Pendy was not pleased with the boat anchor motor. He also is selling a 2.8 kit. Has anyone bought one of those from him? His ad says it will bolt right up to a ZF.
At this point, I just need some advice about whether 3-hundy or 2.8 is better.
Old March 9th, 2010, 07:22 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
[QUOTE=Lucasd2002;208683] His ad says it will bolt right up to a ZF./QUOTE]
many things will bolt together. not all will work together.
I would suggest your friend try driving some Range Rover diesels before commiting. I have both standard and automatic versions at the shop.
I do not currently have a 2.8 here. I will not offer those with autoboxes any more after having done a couple, unless someone has deep pockets and a good sense of humor. 2.8's also require additional expensive cooling equipment, especially if run with an autobox.
http://www.erikssonindustries.com/ will rebuild ZF to diesel spec. You can buy a used box with your motor in the UK for less.
Matt Browne
Old March 9th, 2010, 07:37 AM
Rebuild it or put in a 4.6 block. The 4.6 will really wake up that tired old RRC. I can't imagine that a 23 year old RR is worth putting any money into unless it is really clean otherwise. If he really loves it that's something else. I say drive it until it falls apart.
Old March 9th, 2010, 08:20 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Are you talking about the 2.8 he has on ebay?
FYI that is a Isuzu motor not the 2.8 PS motor
Old March 9th, 2010, 08:54 AM
Lucasd2002's Avatar
Lucasd2002
David Lucas
[VACANT]
Thanks Dave. I saw the displacement and assumed it was the PS motor.
Anybody: what does my friend need to mount a 300tdi in his '87? Are the motor mounts different? Assuming he has the parts from Pendy to convert his ZF, what else would he need for the 300tdi?
Old March 9th, 2010, 09:16 AM
earplugs
I think that a different fuel pump is needed as well as filters. Not sure about motor mounts, he may need different ones welded in. I may be wrong, but I also think he'll need a Tdi radiator with the integral intercooler. Also, consideration for air conditioning and heat. There's probably a 300Tdi a/c compressor mount somewhere out there. That will mean cracking open the a/c system and rerouting all the stuff. Plus a recharge of course.
Just my opinion, but I think a 300Tdi in a RRC will be a dog. If he's OK with that, full speed ahead I say. Whudda I know?
Old March 9th, 2010, 09:28 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
my Defender 200tdi was originally in a RRC in the UK. I know when I ordered it he took the auto tranny off and gave me a lt77. I'm not sure what tranny it was, but I got it from Leachy who use to be on the board.
Old March 9th, 2010, 09:32 AM
I also think you need a different torque converter and flexplate.
I'd also consider changing out the Borg Warner for an R380 and get the lower gears in it.
------ Follow up post added March 9th, 2010 09:49 AM ------
UH, I mean LT230 transfer case
Old March 9th, 2010, 10:08 AM
Lucasd2002's Avatar
Lucasd2002
David Lucas
[VACANT]
It's a 1987 so it has the LT230 [BW started in the RRC in '89, I think].
diesel
More on diesel / manual conversions Delta95 Defender Technical Discussions 37 September 4th, 2008 11:31 AM
Ex-MOD 2.5 diesel 90 EndlessEarth4WD Misc. Chit-Chat 18 January 26th, 2006 01:34 PM
Can you fab a diesel exhaust like a V8 exhaust? solihul Defender Technical Discussions 8 September 7th, 2005 04:09 PM
RRC non-ABS: can you lock brakes? artm Defender Technical Discussions 1 May 30th, 2005 07:13 PM
shop going under, diesel engines artm Defender Technical Discussions 0 May 12th, 2005 04:36 PM
