Diesel Ign Switch pin outs HELP! - Defender Source
Old May 13th, 2015, 06:48 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
For my 19J I just got a new ignition switch (updated) and I am having an issue with pin outs...
Pin 1 White / Red
Pin 2 (there are two spades) (White / Black)
Pin 3 Brown
No pin 4
Pin 5 White
Brown
Brown / Red
White / Red
White / Black
White
The old switch was a tad different and it's not matching up...
It starts, but how do I get the Glows to come on...do I have to add a glow relay or put a manual switch in?...not ideal.
ID:	120682   Click image for larger version
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old May 13th, 2015, 09:51 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Anyone help on this glow issue?
Old May 13th, 2015, 09:55 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
This switch can not handle the glow power, you need to add a relay and take a feed off the start wire, white/red.
I take you don't have a wire diagram, you need too.
Why didn't you get the correct switch? prc2735
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old May 13th, 2015, 10:14 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
You could order the exact replacement IG SW or we have a heavy duty glow plug relay that should work provided the switch handles everything less the Glow Plugs.
RDavisinVA
Old May 13th, 2015, 10:19 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
I wanted to get the new style 1 key for the doors and ignition...I didn't realize that there was a difference...I have the wire diagram, but as I dug I figured out that the 19J needed the switch that had a glow position and the later ones used a relay...
Robert...have any relays available...?
Old May 13th, 2015, 11:05 PM
It is actually the old style that is one key. Best to just get the correct switch.
Old May 14th, 2015, 12:02 AM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
John...I had the old style with an ignition key and separate door keys...this has the single large key and has the longer door tumblers for the Puma doors...from what I have found out is the later engines used the glow relay...
diesel, switch
Hella Euro 7 Pin to 4 Pin Trailer Wiring Adapter Wolf Fabrication For Sale - Parts 2 February 28th, 2013 02:57 PM
Winch Bumper with cut outs for turn signals CDeWan For Sale - Parts 17 February 28th, 2013 03:21 AM
Magnacore or Genuine ign wires? 2yellowlabs Defender Technical Discussions 7 February 22nd, 2011 02:07 PM
Disco 2 radio pin outs JBOD77 Defender Technical Discussions 7 June 17th, 2009 01:03 PM
D90 caliper brake pin - cotter pin help Gardrover Defender Technical Discussions 4 May 29th, 2009 02:01 AM
