Diesel Gel'n - Defender Source
Old January 21st, 2013, 06:25 PM
Grover's Avatar
Grover
Question Diesel Gel'n
I'm in Iowa now and it's in the single digits... Do I need to add anything to my diesel fuel to keep it from gel'n?
Cheers...
Old January 21st, 2013, 06:38 PM
Single malt Scotch.
Old January 21st, 2013, 06:51 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Buy winter diesel
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Yes, you should. Cetane boost is available everywhere. Some also use Kerosene.
I use this stuff all year round.
http://opti-lube.com/xpd-diesel-fuel...r-product.html
Old January 21st, 2013, 07:17 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
As long as you buy your fuel locally in your area, you should have no problem as fuels are winterized for the areas they are sold in.
Old January 21st, 2013, 09:00 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
You can also check your glow plugs to make sure that all of them are working.
Land Rover 110
Old January 21st, 2013, 09:09 PM
I put in 8oz of XPD Optilube in every tank, year round. Bumps my economy and prevents gelling.
Old January 21st, 2013, 09:45 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
When its very cold out a bit of petrol in the tank works wonders. (a very little bit)
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old January 21st, 2013, 10:56 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Opti-lube XPD = cats pajamas.
Old January 21st, 2013, 11:08 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Winter Blend diesel is sold in the winter regions from oct-april (its the only diesel you can get in winter), so unless you are getting extreme temps you do not need to put any additives in.
Old January 22nd, 2013, 05:45 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
It's -30f since sunday night. The diesel bought localy don't gel. Never had to add anything to it as 1,40$/liter is already expensive!
Old January 22nd, 2013, 07:49 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Mechanical Options
You didn't mention the type of diesel you own, so this is a general answer to a general question.
If you still have issues after trying additives...
On eBay you'll see a wide range of heater wraps for metal injection lines, heat exchangers, heated sedimenters & filters, and devices that heat fuel using a single glow plug immersed in the fuel. Some of these use engine coolant, so they won't come into effect until the engine warms up, but those that rely on 12V can be switched on and off as needed.
RDavisinVA
Old January 22nd, 2013, 08:47 AM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
Holler if you need a hand.
PM sent w/ phone #
I'm in West Des Moines.
There should be fuel conditioner available most anywhere...we seem to get "winter" here on an almost annual schedule
Keith
diesel
More on diesel / manual conversions Delta95 Defender Technical Discussions 37 September 4th, 2008 11:31 AM
Ex-MOD 2.5 diesel 90 EndlessEarth4WD Misc. Chit-Chat 18 January 26th, 2006 01:34 PM
Can you fab a diesel exhaust like a V8 exhaust? solihul Defender Technical Discussions 8 September 7th, 2005 04:09 PM
Izuzu diesel swap rustydefender Misc. Chit-Chat 10 August 1st, 2005 03:52 PM
shop going under, diesel engines artm Defender Technical Discussions 0 May 12th, 2005 04:36 PM
