diesel/gas fuel cap - Defender Source
Old December 14th, 2006, 11:37 PM
Noah's Avatar
Noah
Noah
95 D90 TDI
diesel/gas fuel cap
Is there a difference between diesel & gas fuel caps? Mine is suspiciously large making me think there are two...
Need to get another one as I drove off without mine the other day.
Also what are folks running for valving on their bilstein 7100's? I'm going to get my rears revalved; think I got them too stiff.
Thanks.
Old December 15th, 2006, 12:03 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
On the Tdi conversions I have done, I used a p/n703-1631 fuel cap from NAPA. It will hold pressure but not vacuum.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old December 18th, 2006, 06:53 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Noah, 360/85 seems to work pretty well for normally loaded 90's w/hard top. Some say 400/100 but that allways seems a little harsh to me.
Matt Browne
Old December 18th, 2006, 10:07 AM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
Noah,
I am using a Stant locking gas cap that I bought at Pep Boys...mine is a 95 NAS ST converted to diesel and using the existing NAS petrol tank set up.
Old January 10th, 2007, 11:58 AM
Noah's Avatar
Noah
Noah
95 D90 TDI
TTT again.
The cap I'm looking for is not threaded. Instead it has two opposing tabs that you line up with the filler tube and twist (think an inline fuse holder or something). The bottom part was plated metal not plastic and the cap part was a harb ABS type black plastic. It was locking but it's not relevant. I don't have the width of the filler spout on hand but I can safely say it's larger than a normal filler tube. It could easily fit the big-rig diesel pump guns.
Rob: checked out your lead, the parts counter lady showed me a traditional looking plastic threaded gas cap.
Anyone have any other ideas?
shocks: I had 360/80. Took em off and of course one had already lost its pressure. I have such bad luck with shocks. Getting them rebuilt. Trailing arm bushings are ~2-3 years old. Checked the a-arm bushings and those seemed fine. Going on the assumption that the bottom of the shock(s) were not snug to the axle.
Old January 10th, 2007, 12:29 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Its a Land Rover early diesel Defender fuel fill and cap on ECR4.
I'll try to find the part#s
Email:
Old January 11th, 2007, 11:32 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Originally Posted by Noah
TTT again.
Seems like the cap I saw on a 1985 110. Do you have a filter that you could remove from the filler tub/just under the cap?
MonLand
1995 D90 NAS
1996 Discovery NAS
Old January 11th, 2007, 11:43 AM
Noah's Avatar
Noah
Noah
95 D90 TDI
Sweet. I think it's STC4072.
http://www.paddockspares.com/pp/DEFE...g_-_black.html
Old January 11th, 2007, 11:50 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Noah
That part number is in the North American Land Rover price list $43.93 your local dealer can get it for you if your looking for a convient source.
Cheers
Eric
Old January 11th, 2007, 12:02 PM
Noah's Avatar
Noah
Noah
95 D90 TDI
Appears rovers north has it too. No dealerships around bozeman so I'll just use them.
Old January 11th, 2007, 12:15 PM
Eric works at atlantic british, perhap he might have it being that he had the part number.
Old January 11th, 2007, 01:11 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Nope we don't have it. thanks Eric
diesel, fuel, gas
