Diesel fuels in arctic conditions - Defender Source
Old February 8th, 2011, 08:43 PM
I'm always interested in learning more about winterizing my TDI 110 for extreme winter conditions, as I'm looking forward to overlanding into the Canadian arctic at some point in the future. On that note, I found a very interesting link of information on diesel fuels in arctic conditions. It's for dodge rams, but some rams have the bosch ve pump (as you may have seen on youtube), so the same pump on the 300 tdi and 2.8 tgv.
One thing I just learned from this link is that in an emergency, I can use the following alternative fuels if I add 5% clean lube oil to it:
"These fuels are "OK": #1 & #2 Diesel, 1K & 2K Kerosene, Jet-A, Jet A-1, JP-5, and JP-8."
It's also recommended to always run with a snow front/radiator muff in extreme temps. I'm sporting my new ruggedguide radiator muff now!
http://dodgeram.org/tech/dsl/FAQ/diesel_fuel.htm
Here's some other diesel winterizing links for anyone interested. Post up more if you have them!
http://www.arctic-fox.com/
http://www.zerostart.com/coldstart/d...technology.asp
by the way, PA Blanchard does in fact have the heater snow covers for the right wing in stock!
Old February 8th, 2011, 09:34 PM
headdamage's Avatar
headdamage
Andrew
exmod 90 2.5na and a 93/RRC 200tdi
Up here we have winter diesel which is diesel with differing amounts of kerosene in it depending on the area. By the time you get up to the Yukon and NWT there is a lot kerosene in it and you will feel and hear the difference.
Old February 8th, 2011, 10:22 PM
You don't need a radiator muff. You should not cover the intercooler, so it won't really do much.
- Make sure your thermostat closes fully.
- Make sure your heater is in prime condition. For a 110, a second heater or diesel to air heater is a good idea.
- Insulate the crap out of the truck.
- Make sure it is well sealed.
- Install a Webasto....best thing since sliced bread.
As headdamage states, you don't have to worry about the fuel. It is very safe. It is blended for the conditions. I've never heard of anyone gelling. Some good diesel fuel conditioner can't hurt, especially when coming from the south as it will get rid of any water hanging around in the fuel system.
Old February 9th, 2011, 12:50 AM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Very timely. It's been ridiculously cold here in Chicago........0 and below WITHOUT windchill!!!!!!
A few days ago the truck started acting funny.......almost stalling at idle......lot's of white smoke........dropping RPM's when trying to boost up.
Long story short, probably water in the diesel from the gas station tanks. Never saw it coming.
Put in a little diesel conditioner and good as new!!
Would HIGHLY recommend everyone run with something mixed in when the temps are below freezing especially multiple days in a row.
Would definitely recommend radiator cover. Don't understand why covering the intercooler is a problem. Who cares if you drop some HP.........no one's going fast in this cold weather. Am I missing something??
Would think it's better to get temps up and keep up for the engine AND the driver. I've also got an Espar and can't recommend enough. Without out it there is no heat if the car is traveling less than an hour, even at highway speed.
Curious to here others experiences.
Old February 9th, 2011, 08:27 AM
The EGTs will get too high. The EGTs still go high when it is cold out. Why would you not drive fast, just because it is winter?? You do not only lose power. These engine do not have intake air temperature compensation, so seriously overfuel if the air temperature goes high, causing high EGTs.
You probably have a leaking thermostat then. The Espar should make zero difference on the highway. When driven at speed, the engine should still come to normal operating temperature by itself in a few minutes. A radiator muff does very little if everything is running properly. I'm driving around in -25 all of the time.
Old February 9th, 2011, 09:43 AM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Agreed. My 200Tdi is always gets up to 185 within 10-15 minutes, no matter what the temp is outside.
Fuel wise, I put Opti-Lube XPD in each tank. Here's a great study on diesel additives:
http://www.dieselplace.com/forum/sho...d.php?t=177728
Chance
Old February 9th, 2011, 09:45 AM
well i have a new thermostat on the way from RN just to be sure, but I have a short commute and rarely get up to highway speeds during the work week. I run a muff all week long and it makes a big difference in staying and maintaining temperature around town. I also have an EGT gauge, and haven't seen a difference with or without the muff.
That said, if I know I'm going to need to get on the highway for more than 5 minutes, I'll roll up the muff, as at highway speeds the engine will come to temp and stay there pretty quick.
Old February 9th, 2011, 09:53 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Good thoughts on the thermostat although it's all new.
I think the difference between our trucks may also be my intercooler and radiator. Both have been "Pendy-sized" so the radiator is like 4 core massive and the intercooler is full length.
My EGT's have been under 700-800 since the Fall even on the highway under load for stretches. Even with the muff on I've seen so difference in EGT's.
The muff has made a big difference for me maintaining temps and the Espar has been invaluable. Without it my coolant temps are in the 130's!!!!! Even with it the temps never top 160.
I will likely check the thermostat just in case as I would love to run higher temps.
Old February 9th, 2011, 10:13 PM
The thermostat should let nothing through until normal temperature so the size of the radiator makes no difference. Any heat in the upper line is bad. In my experience at least 50% of NEW thermostats leak.
Mine sit where it should (83 C) always unless I'm idling around town, even at -30. No rad muff.
Old February 9th, 2011, 10:17 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Mark......where'd you get the thermostat on your 2.8 and what's the part number?
Old February 9th, 2011, 11:23 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I also got a fuel filter heater which kicks in below 40F.
Old February 10th, 2011, 09:08 AM
it's a 300 tdi thermostat, ordered from RN. I have actually gone through the entire international 2.8 parts catalogue, and identified everything that is common to the 300 tdi with a LR part no.
300 tdi thermostat - ERR3291 (apparently no gasket needed)
Old February 10th, 2011, 10:18 AM
smenzel's Avatar
smenzel
Sandro
1967 Series IIA
We had a Rabbit diesel when I was growing up and would regularly encounter prolonged sub-freezing conditions. My father would add a measuring cup of gasoline to the 12-ish gallon tank of diesel to keep it from gelling. Seems to have worked well except the one time he forgot.
Anyone had any experiences with this? I haven't heard of anyone doing this in years.
Old February 10th, 2011, 10:58 AM
add ins are highlighted in the article I listed the link on.
Old February 11th, 2011, 12:41 AM
smenzel's Avatar
smenzel
Sandro
1967 Series IIA
Thanks, Mark. That lengthy collection of messages about Dodge Ram diesels is definitely informative (my head is spinning from all of the information <G>) but I found no mention of using very small amounts of gasoline to keep diesel from gelling.
Old February 11th, 2011, 09:18 AM
Gasoline would not be a great choice as there is no lubricity and the engine can't burn it. There are a ton of diesel fuel conditioners out there that remove any possibility of gelling and increase lubricity at the same time.
Old February 11th, 2011, 09:44 AM
Naplm00
Matthew
I use a Cetane booster/anti gelling agent from truck stops...its cheap and works
diesel, fuel
More on diesel / manual conversions Delta95 Defender Technical Discussions 37 September 4th, 2008 11:31 AM
Ex-MOD 2.5 diesel 90 EndlessEarth4WD Misc. Chit-Chat 18 January 26th, 2006 01:34 PM
Calling All Diesel Tow Rig Owners ronward Misc. Chit-Chat 14 October 4th, 2005 08:17 AM
Can you fab a diesel exhaust like a V8 exhaust? solihul Defender Technical Discussions 8 September 7th, 2005 04:09 PM
shop going under, diesel engines artm Defender Technical Discussions 0 May 12th, 2005 04:36 PM
