diesel filter unit - Defender Source
Old February 7th, 2015, 01:33 PM
beast's Avatar
beast
the beast
2003/Defender 90
diesel filter unit
Has anyone ever used any hose other than this one? Would 8mm fuel hose work?
Old February 7th, 2015, 01:37 PM
The stock fuel line you see there is just regular nylon tubing. Cheap and available anywhere. You can form it like that by heating it up.
Old February 7th, 2015, 01:50 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I by the Biodiesel compatible hose and connect it with hose clamps.
You can reuse the banjos on the lines in the picture by removing the lines with a razor blade or wire brush wheel.
RDavisinVA
beast's Avatar
beast
the beast
2003/Defender 90
Kool thanks.What about the tips that screw on to the diesel filter unit and the lift pump? Where can i get those?
------ Follow up post added February 7th, 2015 02:52 PM ------
I dont have the banjos or the line. Will go to the hardware to get the lines. Would a hardware have those banjos? Thanks
Old February 8th, 2015, 12:25 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I've got stacks of them.
PM if you need some.
RDavisinVA
diesel
2.5 NA/2.5TD Fuel Filter head with NIB Filter. hillstrubl For Sale - Parts 3 June 1st, 2013 11:46 AM
2.5 Td - Oil Filter and Fuel Filter gonzanc Defender Technical Discussions 5 November 3rd, 2012 01:38 PM
TDI sediment filter - OEM is Delphi CAV filter? jaherring Defender Technical Discussions 2 October 25th, 2010 03:33 PM
Inline fuel filter with diesel? JimC Defender Technical Discussions 36 August 29th, 2009 11:15 AM
Diesel Fuel Filter/Primer Michael Defender Technical Discussions 16 August 15th, 2006 12:45 PM
