Diesel Exhaust Stack? - Page 2 - Defender Source
Old December 18th, 2011, 07:19 PM
Ray_G's Avatar
Ray_G
Ray Gerber
[QUOTE
Come on Ray Ray, stacks will make my truck look badazz. Throw on a big combat action ribbon sticker too.[/QUOTE]
Screw the sticker, if you're going to do that just paint it on the rear tailgate. Both the sticker and the stack say the same thing, BTW.
Old December 18th, 2011, 07:22 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
You guys have to remember that I am asking about how the stack affects the Tdi exhaust, not how it looks. The exhaust would look exactly like a snorkel.
Semper Fi!
Old December 18th, 2011, 08:34 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Originally Posted by bjf View Post
I am eagerly waiting for chapmans response
If he gave me sh*t for my winch mounting plate, he better be all over this.
I too think it will be odd, and you should not have the exhaust ahead of the passenger compartment. Thats just silly for many reasons
If your running without a muffler now, it wont make any difference from your current set up in terms of performance.
I think you touched on this already, but as long as the engine is running, there is no need to worry about having it above water. Even if the engine dies as long as your exhaust manifold is above the water level your ok. That being said, you'd have to be pretty damn deep Even midway up the door isn't as high as where the exhuast manifold connects to the head. If the exhaust manifold is below water then water may go into the cylinders, but that would take awhile as the only way water would displace air is what leaks through the piston rings (your never going to have an engine at rest with an intake AND exhuast valve open at the same time, so the rate at which water could travel back up the exhaust and displace the air is rather slow.
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
My snorkel does get in the way if the trail is woody. I would think that if you took it under the truck behind the seat box and ran it up it might work pretty good. The length would be about the same as stock but may put a small amount of back-pressure but you wouldn't have the bends so maybe not. Would keep the cab warm in the winter.
Land Rover 110
Old December 18th, 2011, 10:10 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Putting an exhaust inside the passenger compartment is ludacris. I hope i read that wrong and its not what your suggesting
Old December 19th, 2011, 08:00 AM
Camel Trophy trucks didnt have smoke stacks
Old December 19th, 2011, 08:04 AM
Wolf Fabrication
Sterling Archer
'08 D3
It's just an idea guys. My biggest hurdle is trying to figure a way to still get fresh air in to the truck through the heater since the exhaust would be taking that spot. The soundness of the idea is starting to crumble....
Semper Fi!
Old December 19th, 2011, 09:24 AM
If you simply remove the plastic tube that goes from the front of the heater to the wingtop the heater will pull air from the engine compartment like many other cars. That would allow your exhaust stack to exit through the fender.
Old December 19th, 2011, 09:33 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
No No, don't give up. I've also been thinking about doing something similar on the 109 and have been accumulating parts to do so. But then my truck already looks like hell.
As for your initial question, with a diesel the less back pressure the better. So, I think it would be performance improvement if you can reduce the number of bends and total lenght. If you can go up a size in tubing diameter even better. I'm actually thinking of coming straight up through the hood.
Old December 19th, 2011, 09:48 AM
Wolf Fabrication
Sterling Archer
'08 D3
Glad to hear I am not the only crazy one!
Semper Fi!
Old December 19th, 2011, 11:17 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Why not cut a hole in the bonnet and have it go straight up like on a backhoe or farm tractor ?
Old December 19th, 2011, 11:18 AM
Wolf Fabrication
Sterling Archer
'08 D3
I'm not going to tractor pulls. I'm trying to find a way to do it tastefully!
Semper Fi!
Old December 19th, 2011, 11:42 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Perhaps the first pic will provide some inspiration, or the following two....
ID:	45108   Click image for larger version
Old December 19th, 2011, 01:00 PM
Naplm00
Matthew
I love stacks
http://youtu.be/SvM6jBn0ZMc?t=59s
Old December 19th, 2011, 02:04 PM
bjf's Avatar
bjf
barry f
94 ST #395
Here you go
Old December 19th, 2011, 02:05 PM
Wolf Fabrication
Sterling Archer
'08 D3
Here you go
WTF is that thing? These people have no eye for design.
If I do move forward and try this, the stack will look exactly like my Mantec snorkel, minus the mushroo top.
ID:	45112   Click image for larger version
Semper Fi!
Old December 19th, 2011, 02:55 PM
I've thought about an exhaust extention, but one that would simply clamp on as needed at the oem end, and run up the rear supported by quick releases added to the rear ladder. when not used could be removed and stored on rack or left at home. would think it would be cheap and easy too, using a quick clamp and a single piece of exhaust expanded on bottom and a short cut to flex, and then a short 90 deg bend and ideally the exhaust flap on top.
Mark Kellgren
KM4BOR
Old December 19th, 2011, 03:08 PM
Naplm00
Matthew
i think that WWII jeeps did this same sort of thing with the "wading" kit
Old December 19th, 2011, 03:36 PM
Wolf Fabrication
Sterling Archer
'08 D3
They did, and same thing with the M38, M38A1, M151, and now the HMMWV.
Semper Fi!
Old December 19th, 2011, 05:19 PM
I don't think breathing in engine fumes and risking burning anyone who casually decides to touch your "other snorkel" is worth it. I'd go with the goofy clamp on wading extension of you really want this.
But I say just don't stall when under water! Talk to Justin - I'm assuming a diesel can survive without hydro locking just as well as any of the poor V8s he's owned. If you stall, then leave it off, and pull plugs etc when back on dry land.
Originally Posted by pendy
I'm here for the D's
ac, diesel, exhaust
NAS D90 300tdi exhaust? Chris Cox Defender Technical Discussions 19 June 13th, 2006 04:59 PM
Anyone know where I can buy an OEM exhaust system for my 2.5 RHD NA Diesel in the USA solihul Defender Technical Discussions 5 October 7th, 2005 02:08 PM
Can you fab a diesel exhaust like a V8 exhaust? solihul Defender Technical Discussions 8 September 7th, 2005 04:09 PM
Wow, more exhaust woes. Hans Misc. Chit-Chat 14 May 27th, 2005 02:08 PM
Diesel exhaust parts JimC Defender Technical Discussions 0 November 3rd, 2004 09:01 AM
