Diesel Exhaust leak...tracking the source - Defender Source
Old April 17th, 2016, 09:12 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
My exhaust system on my 19J is in pretty good nick with what looks to be fairly new front and rear boxes...but I still get a pretty good smell of fumes (not dangerous levels but you can smell it... in the cabin with the windows shut and vents closed...cannot seem to figure out where its coming from...It may be getting pulled in from the fresh air intake but I cannot see any obvious place....what is the best way to track it down? It there a meter that some mechanics or exhaust shop might have that they can sniff the system to help find the leak....
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old April 17th, 2016, 09:41 PM
Is the exhaust exiting to the rear side as stock?
Any leak in the air intake?
Old April 17th, 2016, 09:51 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Yes...to the rear side as stock....the fresh air intake for the "climate system" (yes that is a joke) seems to be solid....and with the engine running and sniffing around under the bonnet and under the car I can't seem to pinpoint anything...
Old April 18th, 2016, 03:35 AM
Omero's Avatar
Omero
Omar Alomar
2000 D110 CSW 6.2 LS (was TD5)
Check the rear door weatherstripping.
Old April 18th, 2016, 06:34 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
You have a couple joints in the pipes with one under the seat box. I would check to see how they are doing as well.
Land Rover 110
Old April 18th, 2016, 06:48 AM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Putting your hand over the exhaust will increase the back pressure and can sometimes show you leaks in the exhaust system.
2 person operation. One to cover the exhaust, one to be under the truck or in the engine bay. Be smart, don't burn your hand. Welding glove or do it when the exhaust is cold.
Old April 18th, 2016, 08:02 AM
I had diesel smell in the cabin as well - turned out to be a leaky spill rail on the fuel return line. The fuel would drip onto the block and when hot, the fumes would enter the cabin.
Old April 18th, 2016, 12:56 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Will do some checking...
ac, diesel, exhaust, rack
tracking down the original owner Rufus Misc. Chit-Chat 1 August 15th, 2012 10:22 AM
300tdi Timing belt tracking Ren Ching Defender Technical Discussions 5 September 15th, 2010 11:32 PM
tracking down my first 90 Mighty Misc. Chit-Chat 13 July 27th, 2007 11:01 PM
Tracking down a vehicle? wicks Defender Technical Discussions 10 April 1st, 2004 11:31 PM
