Diesel Engine Battery Set Up - Defender Source
Old March 28th, 2015, 05:11 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
I own a diesel 110 which currently is set up with one 12V battery. Thinking back to all the Hilux and Land Cruiser diesels used by the locals in Afghanistan they all used two 12V batteries in parallel. Do most of you utilize one or two batteries to increase your cold cranking amps? Would a two battery set up increase reliability for trips into the back country or is the cost of the set up / replacement not worth the gain?
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
1971 109 3 Door (Sold)
Old March 28th, 2015, 06:17 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
I got an optima d31a yellow top. It has 900 cold cranking amps. some say there were quality issues with optimal but mine has worked fine. Expensive but I had a promotive discount that was 40% off.
Old March 28th, 2015, 06:22 PM
You don't need a special battery for starting. I've cold started at -40 with a run of the mill battery. A second one is useful if you want to run things at camp overnight.
Old March 28th, 2015, 07:10 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I always run two batteries, but with a management system. There have been a few times having two saved my ass in the backcountry cold starting a tdi.
Semper Fi!
Old March 28th, 2015, 07:24 PM
One battery is fine as long as it not not an Optima.
Old March 28th, 2015, 07:27 PM
Wolf Fabrication
Sterling Archer
'08 D3
I used to be a die hard optima fan. Then they went to shit. Never again.
Semper Fi!
Old March 28th, 2015, 07:41 PM
They are by far the worst batteries money can buy. I would compare them to Goodyear tires which are expensive and still shit.
Old March 28th, 2015, 07:44 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
¿Mine works fine?
Old March 28th, 2015, 08:18 PM
Originally Posted by mgreenspan View Post
¿Mine works fine?
I think 1 out of 10 are good, so you probably got a good one. I replaced mine about six times and the last one lasted for probably four years. You can ask probably any mechanic and they will likely agree with me on this.
Old March 28th, 2015, 08:42 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Sears platinum are great. Good figures and a great warranty. I have just one in mine and it was abused but starts the diesel no problem
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old March 28th, 2015, 08:53 PM
I'm rockin the Diehard Platinum with zero issues. I had many issues with Optima batteries and won't go down that path again.
Old March 28th, 2015, 08:58 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I had a good Optima...back about 2003.
Now I've got Diehard Platinum in the V8 and a Duralast for the Tdi.
Rent my
Old March 28th, 2015, 09:27 PM
I don't think I have a battery preference as long as it isn't Optima.
Old March 28th, 2015, 09:39 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Haha. I normally just buy whatever. Thought i'd try optima and I guess got lucky.
Old March 28th, 2015, 09:50 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
To be fair, Optimas used to be great, they haven't been in several years.
Old March 28th, 2015, 10:09 PM
The old made in the USA Optima batteries worked good and lasted. The made elsewhere Optima batteries didn't last for me.
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I have mixed feelings regarding 2 batteries in parallel.
Since I have not used this setup, I can't weigh in except to state the advice from others on the subject.
Have been told multiple times by several different people that 2 batters in parallel will not fully charge the same way a single battery will charge.
Am not 100% sure this is correct because the alternator will charge based on battery voltage while also producing the current required for the vehicle use: lights, wipers, heat, AC, and so on.
So have been told that neither of 2 batteries in parallel will fully charge.
I install 2 batteries in any vehicle we use for camping separated by 2 heavy duty 240 amp relays invoked by a 3 way switch:
1.) vehicle battery
2.) auxiliary battery, usually a small audio sound system battery with around 40 amp hrs.
The 3 way switch sends negative current to one relay or the other, or neither and then the alternator and everything less the starter runs off the chosen switched battery.
With this setup you can run your fridge, lights and so on off the auxiliary battery, run it low, start the vehicle off the vehicle battery, charge it back up in just a few minutes and then switch to the auxiliary battery and charge it up again.
If you're gone all day on trail rides and run the auxiliary battery flat, you can still start the engine from the main vehicle battery and then charge the auxiliary battery back up.
Another option is to install a battery protector device like the Havis Charge Guard that will shut down auxiliary devices and protect a battery based on a preset time interval or low voltage threshold.
They run about $80+, but do the job if you don't mind the fridge and other items shutting down when voltage drops to something like 11.8 or when the run time for auxiliary devices exceeds the specified time setting.
Timer settings are controlled by micro switch settings that allow different auxiliary run times after the ignition is turned off.
Some solar panel controllers have similar settings that shut down auxiliary devices when the battery voltage drops to a certain level.
RDavisinVA
Old March 28th, 2015, 10:28 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
One big ass interstate for me... Working so far with all my toys doing their things...
Old March 28th, 2015, 10:57 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
Originally Posted by rdavisinva View Post
I have mixed feelings regarding 2 batteries in parallel. Since I have not used this setup, I can't weigh in except to state the advice from others on the subject. Have been told multiple times by several different people that 2 batters in parallel will not fully charge the same way a single battery will charge. Am not 100% sure this is correct because the alternator will charge based on battery voltage while also producing the current required for the vehicle use: lights, wipers, heat, AC, and so on. So have been told that neither of 2 batteries in parallel will fully charge. I install 2 batteries in any vehicle we use for camping separated by 2 heavy duty 240 amp relays invoked by a 3 way switch: 1.) vehicle battery 2.) auxiliary battery, usually a small audio sound system battery with around 40 amp hrs. The 3 way switch sends negative current to one relay or the other, or neither and then the alternator and everything less the starter runs off the chosen switched battery. With this setup you can run your fridge, lights and so on off the auxiliary battery, run it low, start the vehicle off the vehicle battery, charge it back up in just a few minutes and then switch to the auxiliary battery and charge it up again. If you're gone all day on trail rides and run the auxiliary battery flat, you can still start the engine from the main vehicle battery and then charge the auxiliary battery back up. Another option is to install a battery protector device like the Havis Charge Guard that will shut down auxiliary devices and protect a battery based on a preset time interval or low voltage threshold. They run about $80+, but do the job if you don't mind the fridge and other items shutting down when voltage drops to something like 11.8 or when the run time for auxiliary devices exceeds the specified time setting. Timer settings are controlled by micro switch settings that allow different auxiliary run times after the ignition is turned off. Some solar panel controllers have similar settings that shut down auxiliary devices when the battery voltage drops to a certain level.
Truly appreciate this info. Exactly what I was looking for.
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
Old March 29th, 2015, 09:39 AM
When was that? I started having problems with my Optima about 10 years ago. I haven't had an Optima in probably five or six years.
battery, diesel, engine
Battery switch outside the battery box suggestions rankar Misc. Chit-Chat 7 December 25th, 2014 03:13 PM
Land Rover 90 Diesel ('85 + '86) + 110 Diesel ('86) johan For Sale - Vehicles 15 July 2nd, 2014 10:21 PM
Battery relay for dual battery install plus cables jonathon For Sale - Parts 1 February 3rd, 2014 07:36 AM
Turbo Diesel or Diesel Turbo? Paul K Misc. Chit-Chat 11 April 11th, 2013 11:59 PM
diesel propane injection set-up on a 200tdi 110 paluskat Defender Technical Discussions 1 October 3rd, 2011 03:00 AM
