Diesel conversions install new fuel filter - Defender Source
Old November 10th, 2011, 06:07 PM
kjva
Ken Jackson
1985 110 Wagon
Doug mentioned this very important point on the blown turbo post but thought I would give it it's own thread. If you are doing or have bought a Rover with a diesel conversion be sure to check you have a good fuel filter fitted as well. They are easy to mount in the bulkhead and are cheap . The filters on most petrol engines are not up to the job. A very small investment compared to the cost of a recon injection pump.
Old November 10th, 2011, 06:46 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I heart my Racors
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 10th, 2011, 07:19 PM
The Stanadyne FM-100 mounts in the stock location with zero mods and takes a variety of filters down to 2 microns. More filtration increases injector nozzle life substantially.
Old November 10th, 2011, 08:44 PM
Originally Posted by Antichrist View Post
I heart my Racors
x2! Pendy installed two Racors in mine: prefilter and primary. They last a long, long time!
I believe Pendy uses Racors almost exclusively, which means the are "Pendy Good".
Old November 11th, 2011, 05:57 AM
Naplm00
Matthew
Any particular favor model that is a nice fit? Something with a clear bowl and water seperator would be nice
Old November 11th, 2011, 08:08 AM
I run double 30 micron racors on the boat and then 3 micron spin ons up on the engine. I have gauges that tell me how clogged the filters are so I can determine when to change them-unfortunately they are under deck. Once 60 miles off shore of Cape May Nj on a particularly snotty day I had an engine die. Ran down from the bridge picked up the deck and the gauge on one of the racors was in the red. Try swapping out a 18 inch long filter element while laying on your belly as a boat pitches wildly. Swapped the elements and then had to top it off with clean diesel so the engine would fire. Putting the lid back on and getting the o ring just right was great fun.
Old November 11th, 2011, 10:47 AM
Originally Posted by Naplm00 View Post
Any particular favor model that is a nice fit? Something with a clear bowl and water separator would be nice
Not sure about the Racors, but the Standadynes come with whatever options you like such as glass bowls, heaters, pumps.... Like I said the FM-100 mount bolts straight onto the stock location. There are no o-rings or seals to fiddle with. Filter elements change with no tools. I do not see much call for a pre filter unless you normally run across bad fuel and you are changing filters a lot. A spare fuel filter is something everyone should always carry.
Heads: http://www.thedieselstore.com/templa...0Filter%20Head
Filters, I use a 6" 2 micron one: http://www.thedieselstore.com/templa...FM100%20Filter
Optional parts: http://www.thedieselstore.com/templa...20Module%20Kit
Old November 11th, 2011, 11:01 AM
racors have all those features too, bit no orings or seals may tip hat to stanadyne.
Mark Kellgren
KM4BOR
Old November 11th, 2011, 04:42 PM
pendy's Avatar
pendy
jim pendleton
89'd90
The racor prefilter is important IMO. Clear plastic bottom to track any ingress of water from the fuel station before it wreaks to much havoc. And a good place to help drain it. The mighty priming pump of the racor is a godsend during mantainence as well. The O-rings are a necessary evil to have a sight glass available.
legend in my own mind
Old November 11th, 2011, 04:53 PM
The Stanadynes can have clear bowls and priming pumps as well as I pointed out. All seals are integral with the replaceable elements so they change with the filters making maintenance very easy and foolproof.
conversion, diesel, fuel
Inline fuel filter with diesel? JimC Defender Technical Discussions 36 August 29th, 2009 11:15 AM
More on diesel / manual conversions Delta95 Defender Technical Discussions 37 September 4th, 2008 11:31 AM
Diesel Fuel Filter/Primer Michael Defender Technical Discussions 16 August 15th, 2006 12:45 PM
