Diesel conversion or replace the 4.6? - Page 2 - Defender Source
Old February 7th, 2014, 12:32 PM
Originally Posted by rdavisinva View Post
Joshua: I better not say something like, 10% is on the high side, because we still have a Disco V8 that is running fine and don't want to jinx it. It is however slated for a 300TDI diesel conversion.
Our machine shop just completed 3 prototype adapters that allow the 300TDI to bolt directly to the Rover V8 transmission pattern. I want to make the custom mounts for the 300TDI with this adapter that will bolt directly to the Disco V8 frame mounts and use the big hydraulic filled Mercedes motor mounts to allow an easy low vibration swap from a V8 to a 300TDI, but won't get to this until this summer at the earliest as this is one of many many projects on the list.
Sounds good!
Better that sounds great!
Old February 7th, 2014, 12:47 PM
I agree with Jimmy-rover v8.
While a NAS 90 isn't really a true collectible since there were thousands of them, the 110's are.
I have a heavy "tuned" 300 tdi 130 on 12.5x35's and it will run down the interstate @ 75mph but
its working hard and downshifts on grades are frequent due to the 2.5 liter displacement. Tdi's make decent power once tuned, and can be really fun once modified, but many are dogs in their stock tune. Stick with another 4.6. Atlantic British sells a short block or long block ready to go for reasonable money.
Yeah, and since I swapped to a 2.8 (as I'm no purist) that's one less of the 500 in original form, so I'm helping you out!
That said, the Rover V8 can kiss my ass. I just did some Pendy-approved tweaks to my 2.8 and now my 110 hauls ass. I hit 80 (easily I might say) last week on the highway and have a bit extra when I want to pour it on. For years had no idea my engine had it in it. But like everyone said, if you need total off the hook unbridaled power, then V8 is the way to go..til it breaks.
Mark Kellgren
KM4BOR
Old February 7th, 2014, 12:59 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
I want these hydraulic mounts for the 300 TDI before a lot of other mods... I mean I might have to fab them up myself!
JT
Old February 7th, 2014, 01:17 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Another source for these hydo-mounts are from the 2005 & 6 Jeep Liberty CRD (MB design). Though they show L&R part numbers, they are the same except R one has a removable heat shield. Engine size is comparable as the jeep is a 2.8L. Cost is about $30 each.
Old February 7th, 2014, 01:45 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
good info!
Old February 7th, 2014, 01:49 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Originally Posted by Jymmiejamz View Post
Since its an NAS 110, I would definitely keep the Rover V8. I'm no purist, but I think putting some other non Rover motor in it would devalue it in I'm opinion.
Something about me has always wanted to drop a 4.2L S/C or better yet, 5.0L V8 in either form into a Defender...510hp 461ft.lb
Old February 7th, 2014, 02:02 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
http://www.ebay.com/itm/06-07-VW-TOU...11268677362%26
I mean, 320HP 550LBs of torque while returning mid 20s at highway speeds... what is not to like?
Old February 7th, 2014, 04:12 PM
Fred Lobster's Avatar
Fred Lobster
Pete Gerbine, III
1993 110 (#451)
http://www.defendersource.com/forum/...3&goto=newpost
Then something like this pops up....
Old February 7th, 2014, 04:51 PM
The Dro
Dro
1988 Ninety
Originally Posted by evilfij View Post
i would stick with the v8 personally.
x2.
Old February 7th, 2014, 04:57 PM
A 5.0L supercharged would be awesome and I would totally support someone doing that to an NAS 110. I would not support a Chevy motor swap in anything.
Old February 7th, 2014, 05:04 PM
Originally Posted by Fred Lobster View Post
Has anyone gone from a 4.6 V8 to a 200/300tdi...or the other way around? Regrets? Praises? Advice?
Some other things to think about:
Do you have an LT77 or an R380? Have you factored in the cost of the replacement transmission (or modified transmission) that you will need?
You will need to make frame modifications to fit the new engine.
Are you going to be ok with the current ratio in your tcase with the 200/300tdi?
Old February 7th, 2014, 05:26 PM
I give it two years until this thread turned into a ford 3.2 diesel six speed stick box love fest.
Old February 7th, 2014, 05:57 PM
Fred Lobster
Pete Gerbine, III
1993 110 (#451)
Thanks for all of the input, guys... Looks like I'm about to just pull the trigger on the 4.6. I'll let you know how it goes.
Old February 7th, 2014, 11:36 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Yeah, keep it pure.
As pure as the Buick Skylark (I mean Rover) V8 is...
Go LS and don't look back.
Rent my
ac, conversion, diesel
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
The Official 4.6 Conversion Thread Jon_Winningham Defender Technical Discussions 36 October 27th, 2010 04:36 PM
Diesel Conversion Experiences JimC Defender Technical Discussions 10 December 13th, 2004 05:22 PM
General consensus question 4.0 or 4.6 to replace 3.5 draaronr Defender Technical Discussions 18 August 19th, 2004 05:25 PM
D110 Diesel conversion, towing. Kerr Defender Technical Discussions 3 May 5th, 2004 06:26 PM
