diesel conversion of fuel tank - Defender Source
Old December 5th, 2012, 08:42 AM
kim's Avatar
kim
kim knotts
1994 d-90 300 tdi #199
In doing a diesel conversion of my D-90 I know I have to drop the fuel tank, remove the fuel pump and install a new fuel line.
Does anybody know if I can just disable the fuel pump and keep the fuel sending unit in place?
Old December 5th, 2012, 08:52 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I pulled the pump/sending unit. Removed the pump and replaced the pump with an appropriately sized metal tube connected to a filter. Then replaced the unit.
____________________
Chris Hinkle
Current project - D110 with extended cab and LS3
Old December 5th, 2012, 08:53 AM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
http://www.defendersource.com/forum/...eferrerid=2439
Old December 5th, 2012, 09:12 AM
kim's Avatar
kim
kim knotts
Big thank you,
I need to do better in my search of the past posts.
again thanks!
conversion, diesel, fuel, fuel tank
Diesel conversion - fuel pump removal and new fuel feed jaherring Defender Technical Discussions 0 July 19th, 2010 03:06 AM
Diesel fuel tank vs. Gas tank Tyler Wirken Defender Technical Discussions 9 January 28th, 2010 07:25 AM
Leaky Fuel Tank cbass Defender Technical Discussions 12 June 2nd, 2005 04:50 PM
Air filters and a bad fuel tank valve thingy! RickM Defender Technical Discussions 1 August 9th, 2004 03:29 PM
