Diesel + ATF or 2 Stroke Oil? - Defender Source
Old July 9th, 2013, 10:42 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
I am new to diesels and just wondering what everyone's experience is with diesel additives. I have read about people using 2 stroke oil and some using ATF because of the low sulfer content in the new diesel fuels. Just hoping for some real world experience. Thanks in advance.
This is for my newly acquired HMMWV with 6.2 V8 diesel motor.
MUDSUX
Old July 9th, 2013, 11:25 AM
I was given experienced based guidance by NLX to add a bottle to ATF something like every couple of tanks, and they have 200 TDI's that run thousands of hard kilometers in the C. Amercan jungles every year in their commercial operation and have no mechanical issues.
That's what I'm living by.
Mark Kellgren
KM4BOR
Old July 9th, 2013, 12:00 PM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
ATF in the tank cleared up and issue for me on my 300D last summer. I made an emergency call from Wall, SD to a buddy and Virginia who recommended it. Engine was knocking and running rough at idle after 1200 miles. ATF cleared it up in a tankfull or two.
Old July 9th, 2013, 12:23 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
I like ATF and/or 2 stroke oil. I use whichever I have on hand.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old July 9th, 2013, 01:05 PM
if it was available in charlotte, I'd love to fill up with an occasional tank of B20. that would be like eating fiber for my engine and keep it happy.
Mark Kellgren
KM4BOR
Old July 9th, 2013, 02:27 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Thanks guys. Anyone know what the correct diesel:atf ratio is? Do you guys use Dexron III? And is it legal to do? I read somewhere someone got pulled over and the officer did a "tank-dip" and the gas was tainted with ATF dye and he was fined for it. I can't find the article now though.
MUDSUX
Old July 9th, 2013, 03:00 PM
slorocco
Dan Prasada-Rao
I used 1 quart for a tank full on the mercedes. As for what kind, what ever was on sale or cheap.
Old July 9th, 2013, 03:06 PM
Whenever I swap fuel filters (which is either at every oil change or sometimes between oil changes), I fill up the new filter with the old Type-F ATF fluid. Which essentially accomplishes the above.
In every tank, I put 8oz of Optilube XPD (Gustavo turned me on to it) and it smooths things out considerably and also bumped up my fuel economy probably 3-5% (no joke). I buy it by the gallon and leave an 8oz bottle filled up in the truck to dump into my next fillup.
Old July 9th, 2013, 03:43 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
When I was in the citrus business the DOT guys would test the tanks of our pickup trucks sometimes. They were looking for trucks running offroad diesel on the road in their pickups. There is a dye in offroar diesel. It's a road tax thing. I did know some guys who ran Marvel Mystery Oil in their trucks and got popped with a ticket because the DOT thought they were running off road diesel.
Old July 9th, 2013, 04:11 PM
Howski's Avatar
Howski
Kevin
2002 Land Rover Discovery II
I use ATF every couple tanks. Just by the seat of my pants it seems to run a little smoother than with 2-stroke oil.
I have read that some people use filtered waste motor oil as well, although with not as effective. I've got some old (but unopened) Mobil 1 sitting around that I'm not comfortable with putting it in the 90 since it's pretty old but need to get rid of. Would it be safe to put some in each tank even though it's synthetic? Sorry to steer this OT a little
Old July 9th, 2013, 05:58 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
I run a bit of 2 stroke oil in my 200tdi seems to smooth things out and the smoke clears up considerably too.
If 80:1 works to lube my 2 stroke trial bike that revs to 6000+ RPM I thought that 320:1 would be fine in the diesel just to lube the injection pump, 2000 RPM max, so I put around 1/5 litre in every fill-up of around 60 litres.
Mike Hammond
Old July 9th, 2013, 06:21 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Stanadyne additive if available, 2-stroke oil if not.
2-stroke oil is formulated to burn, ATF is not...
Old July 9th, 2013, 07:58 PM
Yes, a proper diesel fuel conditioner is a lot better idea. ATF has additives that do not burn and they can buildup in the injector nozzles.
Old July 9th, 2013, 09:51 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
Red, what have you had good luck with?
Old July 9th, 2013, 10:00 PM
Dude I'm telling you Opti-lube XPD.
Old July 9th, 2013, 11:15 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Found an independent study about diesel additives:
Study
MUDSUX
Old July 10th, 2013, 06:25 AM
Study
OK That forum wins the worst-spelling award.
Old July 10th, 2013, 09:27 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Bill means that, the forum wins awards for its spelling and grammar mistakes.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old July 10th, 2013, 02:40 PM
Ive always added a little ATF to diesel filters
Old July 10th, 2013, 03:40 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Just ordered some Opti-Lube XPD.
You little rebel, I like you.
diesel
diesel trouble: knocking/loss of oil pressure Noah Defender Technical Discussions 9 February 19th, 2007 10:47 PM
Defender Oil Cooler Status Poll: Please Read. Hans Misc. Chit-Chat 4 March 12th, 2006 10:49 PM
Oil leak rustydefender Defender Technical Discussions 19 December 9th, 2004 09:06 PM
